Use numpy array for a quercy?
5570
12
04-02-2019 05:06 AM
JohannesBierer
I would like to use numpy array from a excel file for a selection of features. Do I have to convert the array to a list first, and how to do that? With the following code I get the following error? Or some better ideas, many files to select?
#!/usr/bin/env python
# -*- coding: iso-8859-1 -*-
import numpy as np
import arcpy
import pandas as pd
import sys, os
# Encoding der Standardausgabe herausfinden
stdout_encoding = sys.stdout.encoding or sys.getfilesystemencoding()
inTable = r"R:\Karto\Bierer2019\FFH_MEKA_FACT\Tabellen\wk13.xlsx"
outP = r"R:\Karto\Bierer2019\FFH_MEKA_FACT\Shape"
fc = r"\\RPKSF001\GIS_DATA\ArcUISTools15\Data\UIS_ALk.gdb\UIS_0100000047100001"
fl = "ALK"
# Tabelle
Flrstkz = pd.read_excel(inTable, index_col=None, na_values=['NA'], parse_cols = "A")
x = np.array(Flrstkz)
arcpy.MakeFeatureLayer_management(fc, fl)
field = 'FLURSTUECKSKENNZEICHEN'
for i in x:
    print i
    sc = "%s = + %s"(field, i)
    print sc
    arcpy.SelectLayerByAttribute_management (fl, "NEW_SELECTION", sc)
    outFc = os.path.join(outP, "WK13_"+ i + ".shp")
    arcpy.CopyFeatures_management(fl, outFc)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
[8334100002890000384]
  File "R:/Karto/zGIS/Python_2019/NumPy/NumPY_MEKA_FAKT.py", line 30, in <module>
TypeError: 'str' object is not callable
Better would be the "quercy" in (np.array)?
JoshuaBixby
MVP Esteemed Contributor
Try changing Lines #28-#31 with:
sc2 = "{} IN ({})".format(field, ",".join("'" + str(i) + "'" for i in x2))
JoeBorgione
Try posting your code again: it didn't make the trip.
That should just about do it....
JoshuaBixby
You missed a critical part of string formatting on line 30:
sc = "%s = + %s" % (field, i)
JohannesBierer
Sorry, my mistake.
JoshuaBixby
My code snippet will address your TypeError, is the rest of the script working now?
JohannesBierer
I changed the code in this, but have problems to code the selection quercy properly.
import numpy as np
import arcpy
import pandas as pd
import sys, os
arcpy.env.overwriteOutput = True
fl = "ALK"
# Tabelle
x1 = np.array(map(str, x))
x2 = x1.tolist()
sc = "'" + field + " IN ({})".format(x2) + "'"
sc1 = sc.replace("[", "")
sc2 = sc1.replace("]", "")
print sc2
arcpy.SelectLayerByAttribute_management (fl, "NEW_SELECTION", sc2)
outFc = os.path.join(outP, "ALK_WK13.shp")
Line 28 is somehow wrong. The print of sc2 looks like this:
'FLURSTUECKSKENNZEICHEN IN ('8334100002890000384', '8334100002890000384', '8334100002890000384', '8334100002890000384')'
but gives a error in Line 37? Invalid expression?
JohannesBierer
With the right code formatting:
import numpy as np
import arcpy
import pandas as pd
import sys, os
fl = "ALK"
# Tabelle
x2 = x1.tolist()
print sc2
JoshuaBixby
Is the field text or numeric, i.e., are those IN values supposed to be strings or numbers?
JohannesBierer
not in the office. Can answer next monday.
JohannesBierer
field is a text field and the in values should be text as well.
