Uploading PDF through FTP using Python
9179
21
03-04-2021 08:53 AM
Bubacz_Hannah
Hello, I am trying to upload a PDF using Python to an outside FTP server. However, I keep getting the error about concatenating string and and file objects.
CODE:
    import ftplib
    # Logging into ftp site with login information
    session = ftplib.FTP("host","username","password")
    print('Logging in')
    # Choosing file to send
    filename = "TEST12142020.pdf"
    filepath = open(r'G:\\GIS\\filepath\\TEST12142020.pdf', 'rb')
    print ('Opened file')
    # Sending the file
    print('Sending file')
    session.storbinary('STOR ' + filepath, filename)
    print('Sent file')
    # Closing file and ftp
    file.close()
    print('Closing file')
    session.quit()
ERROR:
    Logging in
    Opened file
    Sending file
    File "G:\pathname\UploadtoFTPTest.py", line 14, in <module>
    TypeError: cannot concatenate 'str' and 'file' objects
Tags (4)
BlakeTerhune
MVP Regular Contributor
Try putting the file in a simpler directory, like C:\temp\TEST12142020.pdf
Bubacz_Hannah
CODE:
filepath = r'C:\temp\TEST12142020.pdf'
file_object = open(filepath, 'rb')
# Sending the file
session.storbinary('STOR ' + filepath, file_object)
print('Sent file')
ERROR:
Logging in
Opened file
Sending file
File "C:\temp\UploadtoFTPTest.py", line 14, in <module>
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 471, in storbinary
conn = self.transfercmd(cmd, rest)
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 376, in transfercmd
return self.ntransfercmd(cmd, rest)[0]
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 339, in ntransfercmd
resp = self.sendcmd(cmd)
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 249, in sendcmd
return self.getresp()
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 224, in getresp
raise error_perm, resp
ftplib.error_perm: 553 Prohibited file name: C:\temp\TEST12142020.pdf
BlakeTerhune
According to this, try just using the file name in the command.
filename = 'TEST12142020.pdf'
filepath = r'C:\temp\{}'.format(filename)
# Sending the file
session.storbinary('STOR ' + filename, file_object)
print('Sent file')
JoshuaBixby
MVP Esteemed Contributor
The "filename" is the name you want on the FTP Server, not the name of the file on the local machine.  The local file is already addressed through the file object being passed to the command.
Bubacz_Hannah
That worked! Perfect, thank you. I still have some finagling but this is definitely one step closer. If you don't mind, one more question. It uploaded the file but then I got an error about my closing of the file. I tried closing filepath, file_object, and filename and all got the error saying it received a string.
# Sending the file
print('Sent file')
file.close(filepath)
session.quit()
ERROR:
Logging in
Opened file
Sending file
Sent file
File "C:\temp\UploadtoFTPTest.py", line 19, in <module>
TypeError: descriptor 'close' requires a 'file' object but received a 'str'
BlakeTerhune
Don't pass anything as an argument. Just do file_object.close()
However, a better way would be to use the with keyword to open and automatically close the file. Otherwise, you should be using a try/except/finally with open/close.
# define ftp session out here
try:
    with open(filepath, 'rb') as file:
        # Sending the file
        session.storbinary('STOR ' + filename, file)
        print('Sent file')
finally:
    session.quit()
Bubacz_Hannah
Perfect. Thank you so much for all your help.
Bubacz_Hannah
Hello,
Could you help me with one more thing? I need to put it in a certain folder within the ftp site but cannot figure out the code. Thoughts? Thanks!
The folder I need it in:
CODE:
# Sending the file
session.storbinary('STOR {/srv/ftp/pub/gis/crimemaps}' + filename, file_object)
print('Sent file')
ERROR:
<module>
session.storbinary('STOR {ftp.milwaukee.gov/srv/ftp/pub/gis/crimemaps}' + filename, file_object)
ftplib.error_perm: 553 Can't open that file: No such file or directory
BlakeTerhune
Change the working directory before you call the STOR command to copy the file.
session.cwd('/srv/ftp/pub/crimemaps')
# Sending the file
print('Sent file')
Bubacz_Hannah
filepath = r'G:\GIS\Departments\ItmdGis\Users\hbubac\Data and Scripts\Crime Maps\new scripts\{}'.format(filename)
# Sending the file
print('Sent file')
ERROR:
 <module>
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 562, in cwd
return self.voidcmd(cmd)
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 254, in voidcmd
return self.voidresp()
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 229, in voidresp
resp = self.getresp()
ftplib.error_perm: 550 Can't change directory to /srv/ftp/pub/crimemaps: No such file or directory
