Uploading PDF through FTP using Python
13848
21
03-04-2021 08:53 AM
Bubacz_Hannah
Hello, I am trying to upload a PDF using Python to an outside FTP server. However, I keep getting the error about concatenating string and and file objects.
CODE:
    import ftplib
    # Logging into ftp site with login information
    session = ftplib.FTP("host","username","password")
    print('Logging in')
    # Choosing file to send
    filename = "TEST12142020.pdf"
    filepath = open(r'G:\\GIS\\filepath\\TEST12142020.pdf', 'rb')
    print ('Opened file')
    # Sending the file
    print('Sending file')
    session.storbinary('STOR ' + filepath, filename)
    print('Sent file')
    # Closing file and ftp
    file.close()
    print('Closing file')
    session.quit()
ERROR:
    Logging in
    Opened file
    Sending file
    File "G:\pathname\UploadtoFTPTest.py", line 14, in <module>
    TypeError: cannot concatenate 'str' and 'file' objects
Tags (4)
2 Solutions
BlakeTerhune
According to this, try just using the file name in the command.
filename = 'TEST12142020.pdf'
filepath = r'C:\temp\{}'.format(filename)
file_object = open(filepath, 'rb')
# Sending the file
session.storbinary('STOR ' + filename, file_object)
print('Sent file')
BlakeTerhune
The error is pretty clear: Can't change directory to /srv/ftp/pub/crimemaps: No such file or directory
Can you verify that path is correct and the folders exist in the ftp site?
DanPatterson
MVP Esteemed Contributor
You made this a file object.
Did you mean
 filepath = r'G:\\GIS\\filepath'
and the previous to be something like
file_object = open(r'G:\\GIS\\filepath\\TEST12142020.pdf', 'rb')
Then decide what actually needs to go in here
 session.storbinary('STOR ' + ???, ????)
... sort of retired...
Bubacz_Hannah
Hey Dan, so like this? I get the same error.
# Sending the file
session.storbinary('STOR ' + file_object, filepath)
print('Sent file')
Bubacz_Hannah
I also get the same error doing this:
filename = open(r'G:\\GIS\\filepath\\TEST12142020.pdf', 'rb')
# Sending the file
session.storbinary('STOR ' + filename)
print('Sent file')
BlakeTerhune
As the error says, you cannot concatenate 'str' and 'file' objects. You'd have to do something like
# Sending the file
session.storbinary('STOR ' + filepath, file_object)
print('Sent file')
Bubacz_Hannah
Ah, I didn't realize that filepath and file_object were actualy variable names that it would recognize, not just what I chose to call it. I am running the code through Notepad++ with Run on Python27 and got these errors:
Logging in
Opened file
Sending file
File "G:\GIS\Departments\ItmdGis\Users\hbubac\Data and Scripts\Crime Maps\new scripts\UploadtoFTPTest.py", line 14, in <module>
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 471, in storbinary
conn = self.transfercmd(cmd, rest)
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 376, in transfercmd
return self.ntransfercmd(cmd, rest)[0]
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 339, in ntransfercmd
resp = self.sendcmd(cmd)
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 249, in sendcmd
return self.getresp()
File "C:\Python27\ArcGIS10.5\lib\ftplib.py", line 224, in getresp
raise error_perm, resp
ftplib.error_perm: 553 Prohibited file name: G:\\GIS\\Departments\\ItmdGis\\Users\\hbubac\\Data and Scripts\\Crime Maps\\new scripts
BlakeTerhune
You formatted the file path a a raw string but then included the escape backslash. You have to do one or the other. I recommend just using the raw string with single backslashes.
filepath = r'G:\GIS\filepath'
file_object = open(r'G:\GIS\\filepath\TEST12142020.pdf', 'rb')
# Sending the file
print('Sent file')
Bubacz_Hannah
Ah, my bad. You are right. I changed it to this:
filepath = r'G:\GIS\Departments\ItmdGis\Users\hbubac\Data and Scripts\Crime Maps\new scripts'
file_object = open(r'G:\GIS\Departments\ItmdGis\Users\hbubac\Data and Scripts\Crime Maps\new scripts\TEST12142020.pdf', 'rb')
# Sending the file
print('Sent file')
And still got this for an error:
Logging in
Opened file
Sending file
ftplib.error_perm: 553 Prohibited file name: G:\GIS\Departments\ItmdGis\Users\hbubac\Data and Scripts\Crime Maps\new scripts
BlakeTerhune
The command input needs to be a path to the file, not a folder. Try
filepath = r'G:\GIS\filepath\TEST12142020.pdf'
# Sending the file
print('Sent file')
Bubacz_Hannah
Hmmm, looks like the same error. Maybe I need to run it some way different than Python 27? Or my Python version is getting mixed up because I have both ArcMap and ArcPro installed on my computer?
CODE:
# Sending the file
print('Sent file')
ERROR:
Logging in
Opened file
Sending file
ftplib.error_perm: 553 Prohibited file name: G:\GIS\Departments\ItmdGis\Users\hbubac\Data and Scripts\Crime Maps\new scripts\TEST12142020.pdf
