UpdateCursor
1759
5
11-01-2023 03:42 AM
stewart
I am trying to update my attribute field based on a dictionary (join_count_dict) containing {FID:Join_Count}, (eg. {0:1,2:3,3:0,...}
The shapefile has an equal amount of FID as the dictionary, my script works occassionally, any suggestions?
with arcpy.da.UpdateCursor(shapefile, ['FID','Join_Count']) as cursor:
   for row in cursor:
      FID=row[0]
      if FID in join_count_dict:
         row[0] += join_count_dict[fid]
         cursor.updateRow(row)
Any help is much appreciated!
stewart
should it rather be
   for row in cursor:
      FID=row[0]
         row[1] += join_count_dict[fid]
      else:
         row[1] = -1
BlakeTerhune
MVP Alum
This should technically work, but you have an extra line calling updateRow() that should be removed. I don't know if the logic is what you want to happen though. Can you clarify exactly what happens when it doesn't work? Is there an error message?
stewart
There is something else that was ruining it, the extra line is due my poor abilities on posting here. Thanks for the attention though, much appreciated.
VinceAngelo
Esri Esteemed Contributor
Please put your code in code blocks (click on Post options, choose "Edit post (or reply)", hit the "..." in the top-right of the editor menu (to expand the menu block), copy the code text, then click on "</>" and paste into the popup, then clean up the code inside and outside the code block). This will make your code legible.
- V
StaticK
MVP Alum
Is fid declared anywhere?  I see FID, but python is case sensitive so what is fid in join_count_dict[fid]?
