UpdateCursor help
1219
01-23-2019 09:02 AM
RyanPhillips2
Hello,
I am having issues using the update cursor function. This is what I have written, I get no errors but it does nothing:
with arcpy.da.UpdateCursor("test1", ["SYM", "FLD_ZONE","Label", "ZONE_SUBTY"]) as rows:
...     for row in rows:
...        if row[3] == "" and row[1] in ["A", "AE", "AH", "AO", "VE"]:
...           row[0] = 100
...           row[2] = row[1]
...           rows.updateRow(row)
basically if row[3] is empty and row[1] has these " " , update these rows with this
DanPatterson_Retired
/blogs/dan_patterson/2016/08/14/script-formatting  so line numbers can be referred to  Ryan
if row[3] is None and row[1] in ["A", "AE", "AH", "AO", "VE"]:
assuming you don't have any spaces in row[3], in which case you would have to do another 'in' test for
ie row[3] in [" ", None]
RyanPhillips2
Hello Dan,
Thank you so much for replying so quickly. The code works however it is still not populating anything into the fields.
are those the exact codes that are in there?
throw print statements in before the if statement to print out the contents of row[3] and row[1]
