Update point fields with fields in intersecting polygon
3187
07-20-2021 10:48 AM
AliciaShyu
I have 2 feature classes events (points)  and districts (polygons). PolygonsPolygonsPointsPoints
I get new points every day and they need polygon (district) information.
I would like to copy over the fields Week, RecycleRt and RecyCollDay from the polygon feature class to the points.
This is the script that I have so far. I know the arcpy.da.UpdateCursor section is wrong, because I don't understand UpdateCursor and I'm getting a runtime error: Cannot find field 'Week'
import arcpy
arcpy.env.workspace = "\\\\gis\\RecyclingAuditUpdate"
PW = "\\\\Projects\\RecyclingAuditUpdate\\UpdateAudits.gdb"
VPub = "\\\\connections\\AuthUser@VPub_Prd.sde"
RecyAudit = PW +"\\RecyclingAudit"
RecyDistrict = VPub + "\\RecyclingDistrict"
# Select new records
NewSelection = arcpy.SelectLayerByAttribute_management (RecyAudit,"NEW_SELECTION",["Week IS NULL AND RecycleRt IS NULL AND RecyCollDay IS NULL"],"NON_INVERT")
# Select intersecting districts
UpDistricts = arcpy.SelectLayerByLocation_management (RecyDistrict,"INTERSECT",NewSelection, "","NEW_SELECTION")
 Start edit session
edit = arcpy.da.Editor(PW)
edit.startEditing(True, False)
# Update Week, RecycleRt and RecyCollDay fields in RecyclingAudit layer
updateFields = ["Week", "RecycleRt", "RecyCollDay"]
with arcpy.da.UpdateCursor(NewSelection, updateFields) as update_cursor:
    for row in update_cursor:
        row[1] = "Week"
        row[2] = "RecycleRt"
        row[3] = "RecyCollDay"
        update_cursor.updateRow(row)
 Any guidance would be really appreciated. Thanks!
AliciaShyu
OK, I figured out the error. I had to add a common field to both field lists (RecyAuditFieldList and SpatialJoinFields) which are OBJECTID and TARGET_FID.
The edited list looks like this:
RecyAuditFieldList = ["OID@","Week","RecycleRt","RecyCollDay"]
SpatialJoinFields = ["TARGET_FID","Week", "RecycleRt", "RecyCollDay"]
I will most likely have to update this script in the future since it updates all the records, not just the ones with missing fields.
DanPatterson
MVP Esteemed Contributor
rows are zero based, so I am guessing
row[0] = "Week" on line 23
... sort of retired...
AliciaShyu
That fixed the error and the script works but not the way I was thinking 😅
Instead of updating the fields with the corresponding selected polygon's fields. It's just updating them with the words Week, RecycleRt and RecyCollDay 😣
curtvprice
I believe it would be far more efficient to run the Spatial Join tool, add a join from the input to the result, and copy over the values from the result to the input feature class using Calculate Field, or an update cursor.
AliciaShyu
I believe you're correct. I found this post Update points attributes based on there location and updated my script to
import arcpy
RecyAuditFieldList = ["Week","RecycleRt","RecyCollDay"]
SpatialJoin = PW + "\\SpatialJoin_RA"
SpatialJoinFields = ["Week", "RecycleRt", "RecyCollDay"]
arcpy.env.overwriteOutput = True
# Scratch spatial join feature
arcpy.SpatialJoin_analysis(RecyAudit, RecyDistrict, SpatialJoin, "JOIN_ONE_TO_ONE", "KEEP_ALL",
                           'Crdt "Crdt" false true false 8 Date 0 0,First,#,RecyclingAudit,Crdt,-1,-1;'
                           'Address1 "address" true true false 255 Text 0 0,First,#,RecyclingAudit,Address1,0,255;'
                           'Classification "Classification" true true false 255 Text 0 0,First,#,RecyclingAudit,Classification,0,255;'
                           'Status "Status" true true false 10 Text 0 0,First,#,RecyclingAudit,Status,0,10;'
                           'Compliance "Compliance" true true false 5 Text 0 0,First,#,RecyclingAudit,Compliance,0,5;'
                           'Week "Week" true true false 50 Text 0 0,First,#,SolidWasteRecyclingDistrict,Week,0,50;'
                           'RecycleRt "RecycleRt" true true false 50 Text 0 0,First,#,SolidWasteRecyclingDistrict,RecycleRt,0,50;'
                           'RecyCollDay "RecyCollDay" true true false 50 Text 0 0,First,#,SolidWasteRecyclingDistrict,RecyCollDay,0,50',
                           "INTERSECT", None, '')
# Start edit session
edit.startOperation()
# Populate the dictionary from recycling district
valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(SpatialJoin, SpatialJoinFields)}
with arcpy.da.UpdateCursor(RecyAudit, RecyAuditFieldList) as updateRows:
    for updateRow in updateRows:
        keyValue = updateRow[0]
        if keyValue in valueDict:
            for n in range (1,len(SpatialJoinFields)):
                updateRow = valueDict[keyValue][n-1]
            updateRows.updateRow(updateRow)
    del valueDict
# Stop edit operation, stop edit session and save changes
edit.stopOperation()
edit.stopEditing(True)
This script has the following error:
File "S:/Scripts/ShortRecyclingAuditUpdate.py", line 39, in <module>
TypeError: sequence size must match size of the row
I don't understand how UpdateCursor works.
AliciaShyu
