unique values returns only numbers not text
3008
7
03-07-2019 04:47 AM
Nicole_Ueberschär
I have a python script that is supposed to return a unique value of a field.
def unique_values(table, field):
    with arcpy.da.SearchCursor(table, [field]) as cursor:
        return sorted({row[0] for row in cursor})
That works also very fine as long as the values are only numbers. Somehow when values contain also text then it only returns the values that are numbers not the text ones. I don't see why.
I'm using python 2.7 with ArcGIS 10.6.1.
Tags (1)
DanPatterson_Retired
how can a field contain text and numbers? or are you talking about field being either numbers or text?
You can have a field with both or it would fail.
a = ['a', 'a', 'c', 'b', 1, 2]  # cursor equivalent
{i for i in a}  # a set comprehension
{1, 2, 'a', 'b', 'c'}
sorted({i for i in a})  # you can't sort a mixed field
  File "<ipython-input-9-78c584075683>", line 1, in <module>
TypeError: '<' not supported between instances of 'int' and 'str'
JoshuaBixby
MVP Esteemed Contributor
I agree with Dan about having numbers and text in the same field.  Assuming that was possible, sorted cannot work on a sequence containing strings and numbers because comparison operators are not defined between those data types.
>>> l = [1, 2, "hi"]
>>> sorted(l)
  File "<stdin>", line 1, in <module>
TypeError: '<' not supported between instances of 'str' and 'int'
like in my lines 6 -12
JoshuaBixby
Ah, right.  For some reason I missed what was in the code block even though it was right in front of me.  I guess my speed reading lessons aren't working so well. : )
Nicole_Ueberschär
Thank you both for your replies.
I have a field of the type text that has profile numbers which can be 1, 2, 3 but also 2a, 2b, 2c, etc. that's why I store them as text. My script worked before for one file with 1, 2, 3b, 4, 5b, 6, 7, 8  so I guess it is working as long there is only once the number with a letter but not if the same number has many letters.
The script works when I just leave away the "sorted". Thanks!
Nicole_Ueberschär
In case someone else is tumbling over this problem: When I store now my unique values I get a set instead of a list which can't be indexed.
So your numbers aren't numbers, but even if there was text, you can't have a mixed dtype, which a set accepts as does lists, set will handle the duplicates, but only if they are of the same dtype going in.
In short you want to remove duplicates and sort.  The best way to sort text which contains numbers is to use a 'natural sort'
lst = {'1', 3, '3', '3', '7', '7', '8', '8a', 2, '3', '2a', '2b', '2c'}
import re
def natsort(lst):
    """natural sort"""
    lst = [str(i) for i in lst]
    import re
    convert = lambda text: int(text) if text.isdigit() else text
    a_key = lambda key: [convert(c) for c in re.split('([0-9]+)', key)]
    return sorted(lst, key=a_key)
natsort(lst)
Out[20]: ['1', '2', '2a', '2b', '2c', '3', '3', '7', '8', '8a']
notice that there are 2 '3's in the result.  That is because the first 3 in the input is a number and the remaining are text representations.  They would be retained since the input list was of a mixed dtype which can't occur in gdb tables, so that is a moot point.
But the sorting is done in a natural progression
