Ubuntu 18.04:Problem with importing arcpy
1604
04-13-2024 08:12 PM
zak100
I am using:
import arcpy
but I am getting the error:
ModuleNotFoundError: No module named 'arcpy'
I tried to install it using:
pip install -c esri arcpy
ERROR: Could not open requirements file: [Errno 2] No such file or directory: 'esri'
Somebody please guide me.
Zulfi.
Tags (3)
DanPatterson
MVP Esteemed Contributor
you can't pip install arcpy, it must be installed in an esri clone of the original arcgispro python installation.
and arcgis pro must be installed on your machine
Download ArcGIS Pro—ArcGIS Pro | Documentation
Clone an environment—ArcGIS Pro | Documentation
Package Manager—ArcGIS Pro | Documentation
The arcgis package which doesn't include arcpy, has other installation requirements and methods
Install and set up | ArcGIS API for Python
... sort of retired...
Luke_Pinner
MVP Regular Contributor
You're confusing conda installation syntax (-c esri arcpy means install arcpy from the esri conda channel) with pip. ArcPy is not available in PyPi.
You may be able to install arcpy on your Ubuntu device using conda if you have a recent version of ArcGIS Server already installed and licensed on that device.  You can't  run ArcPy without ArcGIS Server (Windows or Linux) or ArcGIS Pro (Windows only).
Documentation:  https://pro.arcgis.com/en/pro-app/latest/arcpy/get-started/installing-arcpy.htm
