Type Error with da.UpdateCursor on Versioned Feature Class
3868
11-03-2020 08:23 AM
JoeBorgione
I'm trying to update a character type field by incrementing numbers but I'm getting:
  File "<ipython-input-1-33b310f15b18>", line 11, in <module>
    with arcpy.da.UpdateCursor(fc,'UNIQUE_ID',select)as cursor:
TypeError: cannot update the table‍‍‍‍‍‍
This is the python code I'm running.
import arcpy
fc = r'\\path\to\versioned\feature class'
ws = r'\\path\to\egdb'
select = "UNIQUE_ID = '0' Or UNIQUE_ID IS NULL"
edit = arcpy.da.Editor(ws)
edit.startEditing(False,False) # changed to True, False for versioned feature class
edit.startOperation()
x = 10100000
    for row in cursor:
        t = str(x)
        row[0] = t
        cursor.updateRow(row)
        x+=1
edit.stopOperation()
edit.stopEditing(True)
As indicated in the title, this feature class is registered as versioned in an egdb.  If I unregister the feature class as versioned, it works just fine.
Bottom line is I need to update aa character type of field for 3,858 records by incrementing a number by 1 such that the final field value will look like records:
10100001
10100002
10100003
10103858
What am I doing wrong here?
Tags (1)
DavidPike
MVP Notable Contributor
Does the workspace need to be set to the versioned connection?
JoeBorgione
Not sure what you mean- the feature class is registered as versioned, but the workspace is just the egdb...
DavidPike
I'm not sure what I mean either! Think I confused the geodatabase versioned view with the versioned FC (luckily and evidently I have no dealings with versioning day-to-day) and thought that the geodatabase connection properties being set to the version might be in the .sde connection file.
I do remember now reading something about the with statement causing issues on cursors for versioned stuff?
Good luck!
JoeBorgione
Thanks for the interest nine the less: we have two egdb's, test and live.  In test, the feature class is unversioned, and luckily for me there is another unique value field that is populated.  I created a table of the other unique id field and the (emtpy) unique field I need to populate and ran an update cursor as shown in my code on that table.  Then I joined that table to the live egdb feature class and calculated my target field with the joined field values  Done...
