Type Error with da.UpdateCursor on Versioned Feature Class
2269
11-03-2020 08:23 AM
JoeBorgione
I'm trying to update a character type field by incrementing numbers but I'm getting:
  File "<ipython-input-1-33b310f15b18>", line 11, in <module>
    with arcpy.da.UpdateCursor(fc,'UNIQUE_ID',select)as cursor:
TypeError: cannot update the table‍‍‍‍‍‍
This is the python code I'm running.
import arcpy
fc = r'\\path\to\versioned\feature class'
ws = r'\\path\to\egdb'
select = "UNIQUE_ID = '0' Or UNIQUE_ID IS NULL"
edit = arcpy.da.Editor(ws)
edit.startEditing(False,False) # changed to True, False for versioned feature class
edit.startOperation()
x = 10100000
    for row in cursor:
        t = str(x)
        row[0] = t
        cursor.updateRow(row)
        x+=1
edit.stopOperation()
edit.stopEditing(True)
As indicated in the title, this feature class is registered as versioned in an egdb.  If I unregister the feature class as versioned, it works just fine.
Bottom line is I need to update aa character type of field for 3,858 records by incrementing a number by 1 such that the final field value will look like records:
10100001
10100002
10100003
10103858
What am I doing wrong here?
That should just about do it....
Tags (1)
DavidPike
MVP Frequent Contributor
Does the workspace need to be set to the versioned connection?
JoeBorgione
Not sure what you mean- the feature class is registered as versioned, but the workspace is just the egdb...
DavidPike
I'm not sure what I mean either! Think I confused the geodatabase versioned view with the versioned FC (luckily and evidently I have no dealings with versioning day-to-day) and thought that the geodatabase connection properties being set to the version might be in the .sde connection file.
I do remember now reading something about the with statement causing issues on cursors for versioned stuff?
Good luck!
JoeBorgione
Thanks for the interest nine the less: we have two egdb's, test and live.  In test, the feature class is unversioned, and luckily for me there is another unique value field that is populated.  I created a table of the other unique id field and the (emtpy) unique field I need to populate and ran an update cursor as shown in my code on that table.  Then I joined that table to the live egdb feature class and calculated my target field with the joined field values  Done...
