True/False Statement for a definition
5843
6
04-09-2015 10:06 AM
MatthewRusso
Hi All,
I am trying to create a True Statement to check if a definition passed the "if"
On line 19 i am running "DEF RENAME" (Changes the name so the tool will run and I can fix it later)
Line 20 I want to know if Rename passed the if statement
My code is to change folders and shapefiles into a GDB while maintaining the structure of the folders.  Please let me know if you have advice or see a large issue.  The way I run this is through the command line.
def rename(variable):
    desc = arcpy.Describe(variable)
    name = desc.name
    new_name = "renamed"
    print name
    if " " or "-" or "0" or "1" or "2" or "3" or "4" or "5" or "6" or "7" or "8" or "9" in name:
        print("{0} is being changed to: {1}".format(name, new_name))
        arcpy.Rename_management(variable, new_name)
    else:
        pass
def import_to_GDB(input_workspace, output_workspace):
    import os
    base = os.path.basename(input_workspace)
    arcpy.CreateFileGDB_management(output_workspace, base)
    for dirpath, dirnames, filenames in arcpy.da.Walk(input_workspace):
        for dirname in dirnames:
            try:
                test = rename(dirname)
                if test == True:
                    dirname = "renamed"
                    dir_path = os.path.join(dirpath, dirname)
                    arcpy.env.workspace = dir_path
                    fcs = arcpy.ListFeatureClasses()
                    fds = os.path.join(output_workspace, base + ".gdb\\")
                    arcpy.CreateFeatureDataset_management(fds, dirname)
                    suboutput = os.path.join(fds, dirname)
                    count = 0
                else:
                    count = 0
            except:
                print("{0} had an error, passing to the next object".format(dirname))
            for fc in fcs:
                count = count + 1
                try:
                    arcpy.FeatureClassToGeodatabase_conversion(fc, suboutput)
                    print("{0} Complete".format(count))
                except:
                    print("{0} had an error, passing to the next object".format(fc))
BlakeTerhune
Are you having an issue running this code or are you just looking for suggestions to improve your code that's already working?
MatthewRusso
Maybe it can't describe the name of a folder?
Sorry I wasn't clear, it is blowing up on me... here is the error:
Runtime error
  File "<string>", line 1, in <module>
  File "<string>", line 26, in import_to_GDB
  File "<string>", line 2, in rename
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\__init__.py", line 1200, in Describe
    return gp.describe(value)
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\geoprocessing\_base.py", line 374, in describe
    self._gp.Describe(*gp_fixargs(args, True)))
IOError: "Buffer" does not exist
DanPatterson_Retired
This will give you some ideas
>>> name = 'bob1'
>>> nums = '0123456789- '
>>> vals = [i for i in nums]
>>> vals
['0', '1', '2', '3', '4', '5', '6', '7', '8', '9', '-', ' ']
>>> for i in vals:
...  print i, i in name
0 False
1 True
2 False
3 False
4 False
5 False
6 False
7 False
8 False
9 False
- False
  False
MatthewRusso
Dan,
Thanks alot you got the ball rolling for some interesting things
MatthewRusso
    import arcpy
    import os
            try:
                x = os.path.join(dirpath, dirname)
                desc = arcpy.Describe(x)
                name = desc.name
                print("Working on: {0}".format(name))
                if "-" in name:
                    new_name = "rename"
                    arcpy.Rename_management(x, new_name)
                    dir_path = os.path.join(dirpath, new_name)
                    arcpy.CreateFeatureDataset_management(fds, new_name)
                    suboutput = os.path.join(fds, new_name)
                    count = 0
                    for fc in fcs:
                        count = count + 1
                        try:
                        except:
                else:
                    count = 0
                    for fc in fcs:
                        count = count + 1
                        try:
                        except:
            except:
This currently works, but it only tests for a "-"  it was passing the if statment everytime if i tested " " .... any ideas?
DarrenWiens2
You could make a list of things to check (checklist below), then find the matches between it and the name:
>>> name = 'john doe1'
>>> checklist = [' ','-','1','2','3','4']
>>> matches = [i for i in checklist if i in name]
>>> matches
[' ', '1']
