To join shapefiles with python code
1940
11-28-2020 07:37 AM
SevincTaghiyeva
Combining data in Arcgis can take a long time. Is there an easier way to do this with python code?
Thanks in advance
DanPatterson
MVP Esteemed Contributor
Use the tools in arctoolbox.  "python code" effectively accesses the same code-base as the tools do and would provide no speed advantages.
You can examine the code snippets associated with the tools in the help files for both arcmap and arcgis pro.
For example
Join Field (Data Management)—ArcGIS Pro | Documentation
scroll to the bottom... no hidden python magic, just a call to the tool itself after the parameters are defined.
... sort of retired...
DavidPike
MVP Notable Contributor
what do you mean by combine or join? i.e. are you merging shapefiles, joining by attributes, joining by location (spatial join)?
SevincTaghiyeva
yes merging shapefiles, joining by attributes
DanPatterson
For example
SevincTaghiyeva
thanks
