The workspace Work.gdb does not exist. Failed to execute (JSONToFeatures).
7917
12
07-16-2021 06:43 PM
DimasPerceka
I want to learn automatic update real time data with python in ESRI training (https://learn.arcgis.com/en/projects/update-real-time-data-with-python/) but i have some trouble. Here I attach the error and the script that was made. Here my script
import sys, os, tempfile, json, logging, arcpy, shutil
import datetime as dt
from urllib import request
from urllib.error import URLError
def feedRoutine (url, workGDB, liveGDB):
    # Log file
    logging.basicConfig(filename="coral_reef_exercise.log", level=logging.INFO)
    log_format = "%Y-%m-%d %H:%M:%S"
    # Create workGDB and default workspace
    print("Starting workGDB...")
    logging.info("Starting workGDB... {0}".format(dt.datetime.now().strftime(log_format)))
    arcpy.env.workspace = workGDB
    gdb_name = os.path.basename(workGDB)
    if arcpy.Exists(arcpy.env.workspace):
        for feat in arcpy.ListFeatureClasses ("alert_*"):
            arcpy.management.Delete(feat)
    else:
        arcpy.management.CreateFileGDB(os.path.dirname(workGDB), os.path.basename(workGDB))
    # Download and split json file
    print("Downloading data...")
    logging.info("Downloading data... {0}".format(dt.datetime.now().strftime(log_format)))
    temp_dir = tempfile.mkdtemp()
    filename = os.path.join(temp_dir, 'latest_data.json')
    try:
        response = request.urlretrieve(url, filename)
    except URLError:
        raise Exception("{0} not available. Check internet connection or url address".format(url))
    with open(filename) as json_file:
        data_raw = json.load(json_file)
        data_stations = dict(type=data_raw['type'], features=[])
        data_areas = dict(type=data_raw['type'], features=[])
    for feat in data_raw['features']:
        if feat['geometry']['type'] == 'Point':
            data_stations['features'].append(feat)
        else:
            data_areas['features'].append(feat)
    # Filenames of temp json files
    stations_json_path = os.path.join(temp_dir, 'points.json')
    areas_json_path = os.path.join(temp_dir, 'polygons.json')
    # Save dictionaries into json files
    with open(stations_json_path, 'w') as point_json_file:
        json.dump(data_stations, point_json_file, indent=4)
    with open(areas_json_path, 'w') as poly_json_file:
        json.dump(data_areas, poly_json_file, indent=4)
    # Convert json files to features
    print("Creating feature classes...")
    logging.info("Creating feature classes... {0}".format(dt.datetime.now().strftime(log_format)))
    arcpy.conversion.JSONToFeatures(stations_json_path, os.path.join(gdb_name, 'alert_stations'))
    arcpy.conversion.JSONToFeatures(areas_json_path, os.path.join(gdb_name, 'alert_areas'))
    # Add 'alert_level ' field
    arcpy.management.AddField(os.path.join(gdb_name, "alert_stations"), "alert_level", "SHORT", field_alias="Alert Level")
    arcpy.management.AddField(os.path.join(gdb_name, "alert_areas"), "alert_level", "SHORT", field_alias="Alert Level")
    # Calculate 'alert_level ' field
    arcpy.management.CalculateField(os.path.join(gdb_name, "alert_stations"), "alert_level", "int(!alert!)")
    arcpy.management.CalculateField(os.path.join(gdb_name, "alert_areas"), "alert_level", "int(!alert!)")
    # Deployment Logic
    print("Deploying...")
    logging.info("Deploying... {0}".format(dt.datetime.now().strftime(log_format)))
    deployLogic(workGDB, liveGDB)
    # Close Log File
    logging.shutdown()
    # Return
    print("Done!")
    logging.info("Done! {0}".format(dt.datetime.now().strftime(log_format)))
    return True
def deployLogic(workGDB, liveGDB):
    for root, dirs, files in os.walk(workGDB, topdown=False):
	    files = [f for f in files if '.lock' not in f]
	    for f in files:
	        shutil.copy2(os.path.join(workGDB, f), os.path.join(liveGDB, f))
if __name__ == "__main__":
    [url, workGDB, liveGDB] = sys.argv[1:]
Here the error message :
(arcgispro-py3) C:\Users\User\Documents>python coral_reef_exercise_local.py https://downloads.esri.com/LearnArcGIS/update-real-time-data-with-python/vs_polygons.json C:\Temp\Work.gdb C:\Temp\Live.gdb
Starting workGDB...
Downloading data...
  File "coral_reef_exercise_local.py", line 80, in <module>
  File "coral_reef_exercise_local.py", line 50, in feedRoutine
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\conversion.py", line 576, in JSONToFeatures
    raise e
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\conversion.py", line 573, in JSONToFeatures
    retval = convertArcObjectToPythonObject(gp.JSONToFeatures_conversion(*gp_fixargs((in_json_file, out_features, geometry_type), True)))
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
CreateFeatureClassName: The workspace Work.gdb does not exist.
I'm very happy if someone can help me with this problem. Thank you
DavidPike
MVP Notable Contributor
I'm not sure why you're creating a path such as
when gdb_name is already set as your workspace.  just try writing to the workspace without specifying the workspace.
arcpy.conversion.JSONToFeatures(stations_json_path, 'alert_stations')
  and do the same for any similar lines, i.e. stop joining gdb_name to a path.
DavidPike
have you created a workspace under that name?
DimasPerceka
can you give me an example?
DavidPike
You've specified a workspace path via sys args for main() with what looks like c:\Temp\Work.gdb , maybe it has to be created first (I'm not a fan of reading screenshotted code so I can't tell).
DimasPerceka
But Work.gdb is automatically appear when i run the previous script :
import sys, arcpy, os, tempfile, json
def feedRoutine (urlworkGDB😞
    # workGDB and default workspace
    print("Creating workGDB...")
    arcpy.env.workspace = os.path.dirname(workGDB)
    arcpy.management.CreateFileGDB(arcpy.env.workspace, gdb_name)
        else:
    with open(stations_json_path, 'w'as point_json_file:
    with open(areas_json_path, 'w'as poly_json_file:
    arcpy.management.AddField(os.path.join(gdb_name, "alert_stations"), "alert_level""SHORT"field_alias="Alert Level")
    arcpy.management.AddField(os.path.join(gdb_name, "alert_areas"), "alert_level""SHORT"field_alias="Alert Level")
    arcpy.management.CalculateField(os.path.join(gdb_name, "alert_stations"), "alert_level""int(!alert!)")
    arcpy.management.CalculateField(os.path.join(gdb_name, "alert_areas"), "alert_level""int(!alert!)")
    # Deployment Logic
    deployLogic()
    # Return
    print("Done!")
    return True
def deployLogic():
    pass
    [url, workGDB] = sys.argv[1:]
    feedRoutine (url, workGDB)
DimasPerceka
Here my script :
def feedRoutine (urlworkGDBliveGDB😞
    # Log file
    logging.basicConfig(filename="coral_reef_exercise.log"level=logging.INFO)
        for feat in arcpy.ListFeatureClasses ("alert_*"😞
    else:
    try:
    except URLError:
        else:
    # Deployment Logic
    # Close Log File
    logging.shutdown()
    # Return
    print("Done!")
    return True
def deployLogic(workGDBliveGDB😞
    for root, dirs, files in os.walk(workGDB, topdown=False😞
        for f in files:
DavidPike
It's still a mess to read, look at code formatting options.
at this moment I can only guess at
being a potential issue, as you already have a workspace set, and gdb_name isn't a full path.
also Exists(workGDB) may be more logical and mitigates unintended effects such as env.workspace defaulting to something if workGDB doesn''t exist, messing up your logic.
DimasPerceka
I'm sorry because I'm a beginner in understanding programming languages, especially python. When I follow your suggestion, the result is still an error
    # Log file
    else:
    try:
    except URLError:
        else:
    # Deployment Logic
    # Close Log File
    logging.shutdown()
    # Return
    print("Done!")
    return True
	    for f in files:
DavidPike
DimasPerceka
Thank you for your help, now the problem is solved.
