The workspace Work.gdb does not exist. Failed to execute (JSONToFeatures).
7986
12
07-16-2021 06:43 PM
DimasPerceka
I want to learn automatic update real time data with python in ESRI training (https://learn.arcgis.com/en/projects/update-real-time-data-with-python/) but i have some trouble. Here I attach the error and the script that was made. Here my script
import sys, os, tempfile, json, logging, arcpy, shutil
import datetime as dt
from urllib import request
from urllib.error import URLError
def feedRoutine (url, workGDB, liveGDB):
    # Log file
    logging.basicConfig(filename="coral_reef_exercise.log", level=logging.INFO)
    log_format = "%Y-%m-%d %H:%M:%S"
    # Create workGDB and default workspace
    print("Starting workGDB...")
    logging.info("Starting workGDB... {0}".format(dt.datetime.now().strftime(log_format)))
    arcpy.env.workspace = workGDB
    gdb_name = os.path.basename(workGDB)
    if arcpy.Exists(arcpy.env.workspace):
        for feat in arcpy.ListFeatureClasses ("alert_*"):
            arcpy.management.Delete(feat)
    else:
        arcpy.management.CreateFileGDB(os.path.dirname(workGDB), os.path.basename(workGDB))
    # Download and split json file
    print("Downloading data...")
    logging.info("Downloading data... {0}".format(dt.datetime.now().strftime(log_format)))
    temp_dir = tempfile.mkdtemp()
    filename = os.path.join(temp_dir, 'latest_data.json')
    try:
        response = request.urlretrieve(url, filename)
    except URLError:
        raise Exception("{0} not available. Check internet connection or url address".format(url))
    with open(filename) as json_file:
        data_raw = json.load(json_file)
        data_stations = dict(type=data_raw['type'], features=[])
        data_areas = dict(type=data_raw['type'], features=[])
    for feat in data_raw['features']:
        if feat['geometry']['type'] == 'Point':
            data_stations['features'].append(feat)
        else:
            data_areas['features'].append(feat)
    # Filenames of temp json files
    stations_json_path = os.path.join(temp_dir, 'points.json')
    areas_json_path = os.path.join(temp_dir, 'polygons.json')
    # Save dictionaries into json files
    with open(stations_json_path, 'w') as point_json_file:
        json.dump(data_stations, point_json_file, indent=4)
    with open(areas_json_path, 'w') as poly_json_file:
        json.dump(data_areas, poly_json_file, indent=4)
    # Convert json files to features
    print("Creating feature classes...")
    logging.info("Creating feature classes... {0}".format(dt.datetime.now().strftime(log_format)))
    arcpy.conversion.JSONToFeatures(stations_json_path, os.path.join(gdb_name, 'alert_stations'))
    arcpy.conversion.JSONToFeatures(areas_json_path, os.path.join(gdb_name, 'alert_areas'))
    # Add 'alert_level ' field
    arcpy.management.AddField(os.path.join(gdb_name, "alert_stations"), "alert_level", "SHORT", field_alias="Alert Level")
    arcpy.management.AddField(os.path.join(gdb_name, "alert_areas"), "alert_level", "SHORT", field_alias="Alert Level")
    # Calculate 'alert_level ' field
    arcpy.management.CalculateField(os.path.join(gdb_name, "alert_stations"), "alert_level", "int(!alert!)")
    arcpy.management.CalculateField(os.path.join(gdb_name, "alert_areas"), "alert_level", "int(!alert!)")
    # Deployment Logic
    print("Deploying...")
    logging.info("Deploying... {0}".format(dt.datetime.now().strftime(log_format)))
    deployLogic(workGDB, liveGDB)
    # Close Log File
    logging.shutdown()
    # Return
    print("Done!")
    logging.info("Done! {0}".format(dt.datetime.now().strftime(log_format)))
    return True
def deployLogic(workGDB, liveGDB):
    for root, dirs, files in os.walk(workGDB, topdown=False):
	    files = [f for f in files if '.lock' not in f]
	    for f in files:
	        shutil.copy2(os.path.join(workGDB, f), os.path.join(liveGDB, f))
if __name__ == "__main__":
    [url, workGDB, liveGDB] = sys.argv[1:]
Here the error message :
(arcgispro-py3) C:\Users\User\Documents>python coral_reef_exercise_local.py https://downloads.esri.com/LearnArcGIS/update-real-time-data-with-python/vs_polygons.json C:\Temp\Work.gdb C:\Temp\Live.gdb
Starting workGDB...
Downloading data...
  File "coral_reef_exercise_local.py", line 80, in <module>
  File "coral_reef_exercise_local.py", line 50, in feedRoutine
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\conversion.py", line 576, in JSONToFeatures
    raise e
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\conversion.py", line 573, in JSONToFeatures
    retval = convertArcObjectToPythonObject(gp.JSONToFeatures_conversion(*gp_fixargs((in_json_file, out_features, geometry_type), True)))
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
CreateFeatureClassName: The workspace Work.gdb does not exist.
I'm very happy if someone can help me with this problem. Thank you
MichaelVolz
Esteemed Contributor
Try putting in some print statements of variables to see what they are returning at various steps within your code, as this is a useful troubleshooting technique.
I would also suggest breaking down the script into smaller components and get each component to work and add back code as you work out the errors that exist in your current code.
Luke_Pinner
MVP Regular Contributor
Can you add your script and the error as code formatted text, not as screenshots please:
How to insert code in your post
DimasPerceka
Thank you for your suggestion, i already modify my post.
Here my script
    # Log file
    else:
    try:
    except URLError:
        else:
    # Deployment Logic
    # Close Log File
    logging.shutdown()
    # Return
    print("Done!")
    return True
	    for f in files:
and here the error message
Starting workGDB...
Downloading data...
    raise e
I'm very happy if you take the time to help me solve this problem. Thank you
