Symbology Drew Order with arcpy
1632
04-21-2022 01:11 AM
OrrGvili
working on Geoprocessing tool, part of the process is saving pdf
cant find how to change the multi ring buffer symbology drawing order when working with the
"UniqueValueRenderer
I really try to avoid splitting the polygons to individual layers
i need the outcome to look like 2 and not 1
using only the outline of the polygon with no color inside
ArcGIS Pro 2.7 ArcPy
RhettZufelt
MVP Notable Contributor
If you are wanting to change the default draw order, that is based on the order the features are saved in the data table.  If you use the sort GP tool, and sort the FC on Area field, Descending, then all the smaller polygons will draw on top of the larger ones as they will be at the bottom of the table.
Though, not sure this will help with multirings.  might have to explode first.
R_
DanPatterson
What do you have now? and what do you want it to look like?
UniqueValueRenderer—ArcGIS Pro | Documentation
You may find converting from multiring simpler after reading the above
... sort of retired...
RhettZufelt
R_
OrrGvili
thanks
Sorting by Descending on the buffer field solved it
