Specifying AGOL as your tile scheme
3581
9
05-02-2021 10:54 PM
Brady
Has anyone got information on how to set the "method" param for AGOL cache creation?
ERROR 000732: Import Tiling Scheme: Dataset ArcGIS Online scheme does not exist or is not supported
Failed to execute (ManageTileCache).
The Python window suggests
Input Tiling Scheme (Optional)
An optional parameter to specify the tiling scheme.
• ArcGIS Online scheme—Use the default ArcGIS Online tiling scheme.
• Import scheme—Import an existing tiling scheme.
• Elevation tiling scheme—Use this tiling scheme for elevation services.
• WGS84 Version 2 tiling scheme—Use this tiling scheme based on WGS84 Version 2.
• WGS84 Version 2 elevation tiling scheme— Use this tiling scheme based on WGS84 Version 2 to build tile cache for elevation data.
but ArcGIS Online Scheme doesn't seem to work. Pro2.7. Any help is appreciated.
Thanks.
folder = "E:\\CITYOFPERTH_IMAGERY\\20201220\\AGOL_CACHE"
mode = "RECREATE_ALL_TILES"
cacheName = "20201220_3857"
dataSource = "E:\\CITYOFPERTH_IMAGERY\\20201220\\20201220_3857.jp2"
method = "ArcGIS Online scheme"
tilingscheme = "#"
scales = "18055.954822;9027.977411;4513.988705;2256.994353;1128.497176;564.248588;282.124294;141.062147;70.5310735"
areaofinterest = "E:\\CITYOFPERTH_IMAGERY\\3857_AGOL_AOI.shp"
maxcellsize = "#"
mincachedscale = "18055.954822"
maxcachedscale = "70.5310735"
arcpy.ManageTileCache_management(
folder, mode, cacheName, dataSource, method, tilingScheme,
scales, areaofinterest, maxcellsize, mincachedscale, maxcachedscale)
Tim_McGinnes
Try this and post the errors if you get any:
arcpy.ManageTileCache_management("E:\\CITYOFPERTH_IMAGERY\\20201220\\AGOL_CACHE","RECREATE_ALL_TILES","20201220_3857","E:\\CITYOFPERTH_IMAGERY\\20201220\\20201220_3857.jp2","ARCGISONLINE_SCHEME",scales= [18055.954822,9027.977411,4513.988705,2256.994353,1128.497176,564.248588,282.124294,141.062147,70.5310735],area_of_interest="E:\\CITYOFPERTH_IMAGERY\\3857_AGOL_AOI.shp")
Tim_McGinnes
If you are not importing a scheme, then leave it out of the parameters. That means you have to specify the parameters coming afterwards specifically though:
arcpy.ManageTileCache_management(folder, mode, cacheName, dataSource, method, scales=scales, area_of_interest=areaofinterest, min_cached_scale=mincachedscale, max_cached_scale=maxcachedscale)
Brady
Thanks for your response. I was just modifying that and have updated my post to reflect my oversight. However, it still won't play nice. 🙂 bypassing that still gives the same error but that param isn't the issue
Tim_McGinnes
You will have to have method="ARCGISONLINE_SCHEME". Are you getting a different error now?
Brady
That was my earlier path and it bombed. 🙂
Tim_McGinnes
Brady
Thanks.  As a regular inline statement, that seems to be all good and is running now. The other form from the help isn't too helpful.
I still think it will give me an error at around the 18 minute mark of WARNING 001518: failed to build tile cache for feature with OID = 0 which is a whole other story that esri couldn't troubleshoot for me. Problem since 2.5 for me
Tim_McGinnes
If I remember correctly, I may have had that warning before also. I think it occurred when it was trying to create a small tile within the AOI, but it didn't intersect with the source raster. Is your AOI polygon completely within the raster extents?
Brady
Yes, the error is persistent regardless of an AIO being used or not. Using different imagery, different coordinate systems, and reinstalls made no difference.
The same formats and other earlier image releases and AOI's all worked for years up until 2.5 when it decided that it wasn't happy anymore.
It has been a headscratcher for Esri
Brady
No go. This was going overnight and didn't generate any outputs other than the standard _alllayers folder and config files. Thanks for your help though. Much appreciated.
