I need to generate the weighted centroid point using Mean Center tool. But it failed with the following error:
arcpy.MeanCenter_stats('Zip5_all_air', r'C:\Users\nanamzn\Documents\ArcGIS\Default.gdb\Zip3_MeanCenter', 'PackageNumber', '#', '#')
Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> File "c:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\stats.py", line 1231, in MeanCenter raise e ExecuteError: Traceback (most recent call last): File "c:\program files (x86)\arcgis\desktop10.5\ArcToolbox\Scripts\MeanCenter.py", line 25, in <module> import SSUtilities as UTILS File "c:\program files (x86)\arcgis\desktop10.5\ArcToolbox\Scripts\SSUtilities.py", line 29, in <module> import matplotlib.path as PATH File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 129, in <module> from matplotlib.externals.six.moves.urllib.request import urlopen File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\externals\six.py", line 90, in __get__ result = self._resolve() File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\externals\six.py", line 158, in _resolve module = _import_module(self.mod) File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\externals\six.py", line 80, in _import_module __import__(name) File "C:\Anaconda2\Lib\urllib2.py", line 94, in <module> import httplib File "C:\Anaconda2\Lib\httplib.py", line 72, in <module> import socket File "C:\Anaconda2\Lib\socket.py", line 47, in <module> import _socket ImportError: DLL load failed: %1 is not a valid Win32 application. Failed to execute (MeanCenter).
I uninstalled Anaconda2 from my machine and rerun the tool. It failed again with different error. May I ask how to fix the problem?
>>> arcpy.MeanCenter_stats('Zip5_all_air', r'C:\Users\nanamzn\Documents\ArcGIS\Default.gdb\Zip3_MeanCenter1', 'PackageNumber', '#', '#')
Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> File "c:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\stats.py", line 1231, in MeanCenter raise e ExecuteError: Traceback (most recent call last): File "c:\program files (x86)\arcgis\desktop10.5\ArcToolbox\Scripts\MeanCenter.py", line 25, in <module> import SSUtilities as UTILS File "c:\program files (x86)\arcgis\desktop10.5\ArcToolbox\Scripts\SSUtilities.py", line 29, in <module> import matplotlib.path as PATH File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 1138, in <module> rcParams = rc_params() File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 971, in rc_params fname = matplotlib_fname() File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 800, in matplotlib_fname configdir = _get_configdir() File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 655, in _get_configdir return _get_config_or_cache_dir(_get_xdg_config_dir()) File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 580, in _get_xdg_config_dir path = get_home() File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 320, in wrapper ret = func(*args, **kwargs) File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 522, in _get_home path = os.path.expanduser(b"~").decode(sys.getfilesystemencoding()) LookupError: unknown encoding: mbcs Failed to execute (MeanCenter).
Thanks a lot!
Anna
When running the following script in windows command line. It works:
import arcpy
... arcpy.MakeFeatureLayer_management(r'C:\ArcGIS_data_analysis\test.gdb\Zip5', "Zip5_point_lyr")
... arcpy.MeanCenter_stats('Zip5_point_lyr', r'C:\ArcGIS_data_analysis\Centroid_analysis\Centroid.gdb\test', 'PackageNumber', 'Zip3', 'PackageNumber')
Why does this happen?
Sounds like you have a couple of versions of python lurking around.
ArcMap uses 2.7 32bit and your command line prompt should look like this
make sure you don't have a 64 bit version installed.
To be sure, you can uninstall all versions of python then do a repair installation of ArcMap to get the right python installed in the C:\Python27\ArcGIS10.5.... file location
To get python 3.x, install ArcGIS Pro, it sets up a conda distribution separate from other version of python
Dan is absolutely right, this is a Python issue, not a issue with the tool. I suspect you have some non-ArcGIS versions of Python installed that messed with the paths. The issue really is how weak Windows is with how it handles paths. The way most people get into this trouble is when they install Anaconda and neglect to un-check the boxes that modify the Windows environment. A sure way to break the Windows setup ArcGIS needs to properly communicate with the correct Python executables and environment.
The fix is to go to Add/Remove programs and remove any Python installs you see, then run a repair install of ArcGIS Desktop (and ArcGIS 64 bit Background Processing, and Pro, if that's installed too). This will get you on the true Python path.
Thanks Dan and Curtis. After I removed the python installed by Anaconda, the tool worked! Thank you!
Great! I was inspired to create a blog post that hopefully will come in future searches by others feeling similar pain.
I have just run on the same issue. Just to let you know that I had removed all other Python installs and keep the one ArcMap is using. I have run the Mean Center again and it worked. I did not even have to run a repair install of ArcGIS Desktop. Thanks for help
