[SOLVED] Print Current Map
1049
05-14-2012 02:50 PM
JoelMadero
Hi All,
Googled around and again failing to find adequate documentation. All I want is to print current map. I see this:
arcpy.mapping.PrintMap
but that doesn't actually print my map. Thanks in advance
curtvprice
There is an example in the online help for the arcpy.mapping PrintMap method.
The only thing missing in their example is how to get the current map document:
mxd = arcpy.mapping.MapDocument("CURRENT")
arcpy.mapping.PrintMap(mxd)
Does this help?
JoelMadero
Does this help?
That did the trick. Thank you much Curt
