Singlepart to Multipart
3655
05-01-2021 03:53 AM
FinbarGillen
I have a dataset of polygons.. a large quantity of these share a common ID.
The goal is to have a final dataset with one row per ID but also preserve the polygon boundaries (dissolve tool will not work in this case).
Was looking for singlepart to multipart tool where I could group by an ID field but can't find any... has anyone done this in ArcPy and would be willing to share their code? If there is a tool that I have missed even better.
Thanks!
JayantaPoddar
Polygons having common end vertices, when dissolved, will get their boundaries merged for a single-feature.
That said, check if the following workaround works for you (Be careful: This workflow will contain induced errors).
Step-1: Create a negative buffer
Step-2:
Use Dissolve on the buffered polygon FC.
On a smaller scale, the dissolved/ buffered polygon looks fine.
But when zoomed into the boundary (1:10 here), you can see the gaps.
N.B.: Use these steps at your own discretion 😉
Think Location
JayantaPoddar
Step-2:
Think Location
DavidPike
MVP Notable Contributor
Multipart polygons cannot share edges.  IMHO the method Jayanta describes is the only pragmatic approach to this.
FinbarGillen
Thanks for the reply guys! Will use the accepted solution above for now!
