Service Support Email for Citizen Problem Reporter not working after configured.
1079
11-25-2020 09:31 AM
JeffreySteele
When I run the script below I receive the following error any help you can give me would be greatly appreciated. I am very new to this portion of ESRI.  Thank you!
File "C:\ServiceSupport\send_email.py", line 99, in <module>
to_addresses[:] = (value for value in to_addresses if value != '' and value != '#')
TypeError: 'str' object does not support item assignment
from email.mime.multipart import MIMEMultipart
from email.mime.text import MIMEText
import smtplib, sys
class EmailServer(object):
    def __init__(self, smtp_server, smtp_username=None, smtp_password=None, use_tls=False):
        self._server = smtplib.SMTP(smtp_server)
        if use_tls:
            self._server.starttls()
        self._server.ehlo()
        if smtp_username and smtp_password:
            self._server.esmtp_features['auth'] = 'LOGIN'
            self._server.login(smtp_username, smtp_password)
    def __enter__(self):
        return self
    def send(self, from_address="", reply_to="", to_addresses=[], cc_addresses=[], bcc_addresses=[], subject="", email_body=""):
        msg = MIMEMultipart()
        msg['from'] = from_address
        if reply_to != "":
            msg['reply-to'] = reply_to
        if len(to_addresses) > 0:
            msg['to'] = ", ".join(to_addresses)
        if len(cc_addresses) > 0:
            msg['cc'] = ", ".join(cc_addresses)
        msg['subject'] = subject
        msg.attach(MIMEText(email_body, 'html'))
        recipients = to_addresses + cc_addresses + bcc_addresses
        if ('') in recipients:
            recipients.remove('')
        if len(recipients) == 0:
            raise Exception("You must provide at least one e-mail recipient")
        self._server.sendmail(from_address, recipients, msg.as_string())
    def __exit__(self, exc_type, exc_value, traceback):
        self._server.quit()
def _add_warning(message):
    try:
        import arcpy
        arcpy.AddWarning(message)
    except ImportError:
        print(message)
def _set_result(index, value):
    try:
        import arcpy
        arcpy.SetParameter(index, value)
    except ImportError:
        pass
if __name__ == "__main__":
    smtp_server = 'smtp.****.*********.**.gov'
    smtp_username = '***@.****.*********.**.gov'
    smtp_password = '********'
    use_tls = 'smtp.****.*********.**.gov'
    from_address = '***@.****.*********.**.gov'
    reply_to = '***@.****.*********.**.gov'
    to_addresses = '***@.****.*********.**.gov'
    cc_addresses ='***@.****.*********.**.gov'
    subject = 'You have a New Inquiry'
    email_body = '*:\***********\internal_email_template2.html'
    subject = 'Thank you for your Report'
    email_body = '*:\***********\user_email_template2.html'
    # Remove empty strings from addresses
    cc_addresses[:] = (value for value in cc_addresses if value != '' and value != '#')
    bcc_addresses[:] = (value for value in bcc_addresses if value != '' and value != '#')
    all_addresses = to_addresses + cc_addresses + bcc_addresses
    try:
        with EmailServer(smtp_server, smtp_username, smtp_password, use_tls) as email_server:
            email_server.send(from_address, reply_to, to_addresses, cc_addresses, bcc_addresses, subject, email_body)
        _set_result(11, True)
    except Exception as e:
        _add_warning("Failed to send e-mail. {0}".format(str(e)))
       _set_result(11, False)
RandyBurton
The error indicates that to_addresses is a string value, but the line of code is expecting to process a list.
>>> to_addresses = ['[email protected]', '[email protected]', '', '#' ]
>>> to_addresses
['[email protected]', '[email protected]']
Per the line of code, empty values and '#' will be removed from the list.
It also looks like you are setting up to process two email messages in your lines of code after __name__ ==  __main__.   But you are just resetting the variables to new values, so only the last value will actually be used. Since bcc_addresses is not defined, this will also cause an error.
