Send a feature to a map using Python
6225
13
10-30-2014 10:30 AM
StephenEldridge
I have python script that creates a point feature class.  How do I send that feature to an existing map using Python?
DarrenWiens2
DanPatterson_Retired
do you mean makefeaturelayer ?
StephenEldridge
My script already makes the feature and puts it into a file geodatabase.  I would like it to also take that same feature class and drop it into an ArcMap.
so I assume you have ArcMap set to add results to display and set visibility on?  And I have to ask the obvious...you are running this from within ArcMap?  some people have tried to add layers to arcmap without it being open
StephenEldridge
I am using Python script that runs in the background.
# Import arcpy module
import arcpy
#Import Time and Date
import time
import datetime
#Sets a variable to hold today's date in year month day (yyyymmdd)format to tag feature output name with the current date
currentdate = datetime.date.today().strftime("%Y""%m""%d")
# Overwrite pre-existing files
arcpy.env.overwriteOutput = True
# Local variables:
Changes = "\\\\MyData\\Working_Data.mdb\\Changes"
Changes_Layer = "Changes_Layer"
Updates = "\\\\MyData\\My_Data.gdb\\Updates\\Updates"+str(currentdate)
# Process: Make XY Event Layer
arcpy.MakeXYEventLayer_management(Changes, "longitude", "latitude", Changes_Layer, "", "")
# Process: Feature To Point
arcpy.FeatureToPoint_management(Changes_Layer, Updates, "CENTROID")
Now I would like to add Python script that will take "Updates"+str(currentdate)" and add it to MyDataUpdates.mxd
DarrenWiens2
I believe you're looking for arcpy.mapping.AddLayer().
grief...
StephenEldridge
addLayer is what  am trying to use now but I keep getting this error:
  File "\\c:\MyLocation\Tools\Scripts\Changes.py", line 39, in <module>
    df = arcpy.mapping.ListDataFrames(mxd, "Update")[0]
IndexError: list index out of range
This one has me stumped.
Here is the code:
import arcpy
import time
import datetime
# Local variables:
Changes = "\\\\c:\\MyLocation\\\\Working_Data.mdb\\Changes"
Update = "\\\\c:\\MyLocation\\MyGeo.gdb\\Updates\\Updates"+str(currentdate)
#Add layer into primary map document
addLayer = Changes_Layer +str(currentdate)
mxd = arcpy.mapping.MapDocument("\\\\c:\myLocation\\MyMap.mxd
arcpy.mapping.AddLayer(df, addLayer, "TOP")
StephenEldridge
The script also corrupts my mxd to the point I cannot save it.
have you tried this on a local drive to rule out network issues?
