Selecting rows using For Loop in python.
1468
09-30-2013 04:11 AM
MANESK
I've a set of 10000 records in which i've to select only alternate set of 100 records which
has continuous FID..(i.e selection should be 1 to 100, 201 to 300,401 to 500..likewise).. on a single execution..
i need a script in python or vb script ..
Pls suggest...
i'm a newbie to python..
markdenil
Use Make Feature Layer or Make Table View to create a sub set of your feature class or table.
The where clause in these tools will grab only the features you want to process.
The where can be set up in a variety of ways,
largely dependant on how clever you want to appear to someone reading your code.
the simplest might be to use a nested python list of the discrete start and stop points for your ranges
InputFC_var = ...full path to the FC...
outputLyr_var = "outputLyr"
rangeList = [
        [1, 100],
        [101, 200],
        [201, 300]]
for r in rangeList:
    whereClause = ' "FID" >= r[0] AND "FID" <= r[1] '
    arcpy.MakeFeatureLayer_management(InputFC_var, outputLyr_var, whereClause)
    ...other stuff you want to do...
MANESK
Thanks for your reply...
I ve a set of around 50,000 records.. If i ve to specify the range ,it'll take some time..
So any other option..
kindly reply..
RDHarles
This will get you the numbers you are looking for.  Then you can use the variables "lowRange" & "highRange" to select those records.
set=1
lowRange=1
for highRange in range(100,50001,100):
    set=set+1
    if set % 2 == 0:
        print "From "+str(lowRange)+" To "+str(highRange)
    lowRange=lowRange+100
