Arcpy SQL Clause not working
1371
08-25-2013 12:53 PM
JakeBryson
Hi All
I am running the Arcpy below in the Catalougue Python window but the result is unexpected. Basically it looks as if the variable rSQL is recognised, however the native underlying SQL functions of Distinct and Group By arn't being interpreted correctly as native SQL functions. Does anyone have any ideas as I'm really stuck. I'd also like to wrap this code in a loop which lists all Distinct layers for each feature class within a File Geodatabase basically so the output looks like.
FeatureClassName1,DistinctLayerName1
FeatureClassName1,DistinctLayerName2
FeatureClassName1,DistinctLayerName3
FeatureClassName1,DistinctLayerName4
FeatureClassName1,DistinctLayerName5
FeatureClassName2,DistinctLayerName1
FeatureClassName2,DistinctLayerName2
FeatureClassName...n...n,DistinctLayerName...n...n
Thanks Jake
>>> import arcpy
... fc = "D:\CAD_Data_Anthony_Ramen\CAD_Data_Examples.gdb\Akaroa_Street_GIS_dwg_Annotation"
... namefield = "Layer"
... rSQL = ('Distinct','GroupBy')
... cursor = arcpy.da.SearchCursor(fc,namefield,None,None,None,rSQL)
... for row in cursor:
...     print (row[0])
PROPERTY_STREET_NUMBER_LABEL_$1
TEXT
marking
STREET_NAME_LABEL_LABEL
dimension
TEXT
JamesCrandall
Please list the exact Feature Class name, its storage container type and the where clause you'd like to filter by.  The way you have it now is an invalid SQL statement as the "SELECT *" is hardcoded into it and cannot include DISTINCT or GROUP BY, this requires a subquery (which also depends upon the storage database you are using).
http://resources.arcgis.com/en/help/main/10.1/index.html#//00s50000002t000000
http://resources.arcgis.com/en/help/main/10.1/index.html#//00s500000033000000
oscarespitia
hi james
would you give me a example for 'group by' with a subquery?, please
