query = 'OID in '+OIDlist gp.SelectByAttribute(layername, "ADD_TO_SELECTION", query)
query = 'OID in '+str(OIDlist) gp.SelectByAttribute(layername, "NEW_SELECTION", query)
oidList = [1,2,3,4,5,6] gp.SelectLayerByAttribute(layername, "ADD_TO_SELECTION", "OBJECTID in (" + str(oidList)[1:-1] + ")")
gp.MakeFeatureLayer_managment(fc, "fl", "OBJECTID in (" + str(oidList)[1:-1] + ")") gp.Clip_analysis("fl", cookieCutterFC, blah, blah)
...tuple list instead of a list list...
oidList = [6,4,2,6,8,1] oidList.sort() gp.MakeFeatureLayer_managment(fc, "fl", "OBJECTID in (" + str(oidList)[1:-1] + ")")
oidList = [6,4,2,6,8,1] oidList.sort() gp.MakeFeatureLayer_managment(fc, "fl", "OBJECTID in " + str(tuple(oidList)))
#blah blah else: #Process: Try to select the arcs message = "Selecting features. Please wait..."; showPyMessage() selectionOidList = list(currentSearchOidList) selectionOidList.sort() gp.SelectLayerByAttribute_management(inLayer, "NEW_SELECTION", oidFieldName + " in (" + str(selectionOidList)[1:-1] + ")") #blah blah #blah blah #Process: Proceed with getting the selected feature count... if data source is in SDE this can take a while! selectedFeatureCount = int(gp.GetCount_management(inLayer).getoutput(0)) if selectedFeatureCount > 0: message = "Selected " + str(selectedFeatureCount) + " features..."; showPyMessage() elif sdeDataSourceFlag == True and selectedFeatureCount == 0 and len(selectionOidList) > 0: #Process: Build an SDE look up table to handle the large selection! message = "Building ArcSDE selection table. Please wait..."; showPyMessage() lookupTblName = "SEL_OID_" + string.lower(os.environ.get("USERNAME")) + "_" + time.strftime('%Y%m%d%H%M%S') gp.CreateTable_management("in_memory", lookupTblName, "", "") gp.AddField_management("in_memory\\" + lookupTblName, "SEL_OID", "LONG") insertRows = gp.insertcursor("in_memory\\" + lookupTblName) for currentSearchOid in currentSearchOidList: insertRow = insertRows.newrow() insertRow.SEL_OID = currentSearchOid insertRows.insertrow(insertRow) del insertRow del insertRows parentWorkspace = parentFC[0:-len(parentFC.split("\\")[-1]) - 1] #if stream dataset (aka "the parent" ) is in SDE put the lut there too lookupTblPath = parentWorkspace + "\\" + lookupTblName gp.CopyRows_management("in_memory\\" + lookupTblName, lookupTblPath, "") gp.Delete_management("in_memory\\" + lookupTblName, "") gp.ChangePrivileges_management(lookupTblPath, "public", "GRANT", "GRANT") gp.SelectLayerByAttribute_management(inLayer, "NEW_SELECTION", oidFieldName + " in (SELECT SEL_OID FROM " + lookupTblName + ")") gp.Delete_management(lookupTblPath, "") message = "Selected " + str(count2) + " features..."; showPyWarning() else: message = "ERROR: No features were selected! Exiting script..."; showPyError(); sys.exit() del currentSearchOidList message = "REFRESH THE ARCMAP VIEW TO DISPLAY NEWLY SELECTED FEATURES!"; showPyWarning() #*****************GEOPROCESSING STUFF ENDS HERE****************************** #Indicates that the script is complete message = sys.argv[0] + " is all done!"; showPyMessage() except: message = "Error in script! Consult log file " + logFile + " for details..."; showPyError() message = "\n*** LAST GEOPROCESSOR MESSAGE (may not be source of the error)***"; print >> open(logFile, 'a'), str(time.ctime()) + " - " + message print >> open(logFile, 'a'), gp.GetMessages() message = "PYTHON TRACEBACK INFO: " + traceback.format_tb(sys.exc_info()[2])[0]; print >> open(logFile, 'a'), str(time.ctime()) + " - " + message message = "PYTHON ERROR INFO: " + str(sys.exc_type)+ ": " + str(sys.exc_value) + "\n"; print >> open(logFile, 'a'), str(time.ctime()) + " - " + message message = "\n*** PYTHON LOCAL VARIABLE LIST ***"; print >> open(logFile, 'a'), str(time.ctime()) + " - " + message #don't print this mess to ArcToolbox (just the logFile)! variableCounter = 0 while variableCounter < len(locals()): message = str(list(locals())[variableCounter]) + " = " + str(locals()[list(locals())[variableCounter]]); print >> open(logFile, 'a'), str(time.ctime()) + " - " + message #don't print this mess to ArcToolbox (just the logFile)! variableCounter = variableCounter + 1]
Step1 to any ESRI geoprocessing analysis: Copy all the data to a local hard drive (perferably in .shp or FGDB format), then proceed with the analysis (i.e. Don't use data directly from a network connection!).
