Select by Attributes Using Python List
12589
11
09-08-2011 05:59 AM
BenYoungs
All,
Is there an efficient way to select multiple features in a feature class using a Python list containing OIDs of the features?
What I have set up right now is the following:
for OID in OIDlist:
     query = 'OID = ' + OID
     gp.SelectByAttribute(layername, "ADD_TO_SELECTION", query)
That works, however it is painfully slow. Is there another approach that I can use (possibly avoiding the GP SelectByAttributes tool?) that would be more efficient?
My desired end result is a layer file that only contains the features with OIDs specified in the list.
Thanks in advance.
BenYoungs
Chris,
You're definitely right on the merits of using local data for geoprocessing. However, I was trying to bypass that if possible because this tool will be running on potentially hundreds of feature classes.
I think this definitely still gives me something to work with, and I will take a look at the work-around you provided and see if that works for me.
Again, thanks to you both for the help.
LeanneSulewski
Thank you!  You guys solved a python issue I was having!!  Thanks a bunch!  You guys save me a ton of time!
