Script to find 'move edits to base' versioning setting
1419
11-25-2021 05:36 AM
ÅsaBlomberg
We have many hundred feature classes and we discovered that some of them by mistake have the versioning setting 'move edits to base'.
Is there a way to find out which feature classes that have this setting? Maybe with SQL or python?
Microsoft SQL Server, ArcGIS Enterprise 10.8
DanPatterson
MVP Esteemed Contributor
Is this the tool that was used?
Register As Versioned (Data Management)—ArcGIS Pro | Documentation
or one of the other tools in the table of contents tree for the link above?
If it was, you would have to batch the tool
... sort of retired...
ÅsaBlomberg
Thank you Dan! I will try to write a python-script with this function.
ÅsaBlomberg
Hi Dan!
It seems I have to un-register the datasets as versioned first?
I get error ERROR 000130: The dataset is already registered as version
