Script are changed by ESRI with g_ESRI_variable_1, g_ESRI_variable_2
9475
13
08-10-2018 12:09 AM
simoxu
by MVP Alum
It's a surprise to me that ArcGIS Pro changes the python code in my script tool when I pack the project and upload the ppkx to ArcGIS Online.
Here is the first a few lines of code for one script tool in the unpacked ppkx, please pay attention to the codes between "Esri start of added imports" and "Esri end of added variables"
# Esri start of added imports
import sys, os, arcpy
# Esri end of added imports
# Esri start of added variables
g_ESRI_variable_1 = "EventID = '{}'"
g_ESRI_variable_2 = os.path.join(arcpy.env.scriptWorkspace,'..\\..\\..\\Users\\simoxu
\\AppData\\Local\\Esri\\ArcGISPro\\Staging\\SharingProcesses\\0038
\\RDA Tools for ArcGIS Pro\\p20\\current_checkout_attachments')
# Esri end of added variables
# Name:        rda_checkout
# Purpose:     checkout the assessment for a specific event and map it
# Author:      simoxu
# Created:     27/07/2018
from arcpy import da
import os,sys
import shutil
In one place in my original code, I have the following line:
checkout_image_path= os.path.join(homefolder,"current_checkout_attachments")
But it was replaced with the following code, which is causing fatal error for the tool itself.
checkout_image_path= os.path.join(homefolder,g_ESRI_variable_2)
It's quite strange that ArcGIS Pro packaging tool will change my code without informing me ---  I only found out this when I shared the project package with others and then was told the tools could not run properly.
Is it only me? Any advice?
I am using ArcGIS Pro 2.2.1, by the way.
Thanks.
simoxu
by MVP Alum
Yes, I removed the history completely. I seriously think this is a bug in the Package Project tool.
It makes sense to analyze the code when you publish the geoprocessing tool as a service and make sure all the folders used in the code are accessible by the server, But as a project package, this process is not needed and the folders are relative to the project folder, which will be created when you unpack the project in ArcGIS Pro.
DanPatterson_Retired
I agree... it is that user folder with your name that still bugs me... don't know why it appears, unless your data were in it or it belongs to history
simoxu
by MVP Alum
A bug related to this topic has been confirmed by ESRI.
#BUG-000116650 Python script within the default toolbox in a project is appended with an invalid directory path after sharing the project as a project package.
myESRIUName
I know this thread is very old, but I thought I'd pass along some info related to it because I've just gone through a couple of days dealing with this too. I only just found the addition of a "g_ESRI_variable_1" variable to a script in a Project Package I had created because I was testing it to ensure what I had in mind would work. It didn't and I've spent two days trying to figure out why, but that's beside the point. I know now.
When I finally did stumble on this "g_ESRI_variable_1", I was reminded that I had run into the exact same problem about 10-15 years ago with ArcGIS Server 9.3 and again with 10.1. At both times, I was struggling with getting Geoprocessing Services to run properly after publishing. Eventually, looking into the v101 folder on the server, I discovered what ArcGIS Server was doing to the code during the publishing process each time. And each time, fixed the problems by "over-complicating" the things that the ArcGIS Server was changing erroneously. You'll get the idea in a moment. My point is that this is not a new problem only related to Pro. It's been in their source code for a while and they seem to feel it's a good thing to change code without informing the user. Otherwise, they would have done something about it by now.
What I've been struggling with over the last couple of days is that I have a project with scripts that I am putting in source control as a project package. The project's name is "my_project_name" and the first thing each script within it does when invoked is verify that it is running within the "my_project_name" project because that project is structurally set up as it needs to be for all of these scripts to work.
Unfortunately, ArcGIS Pro is finding this:
project_name = "my_project_name"
aprx = arcpy.mp.ArcGISProject("CURRENT")
pos = aprx.filePath.rfind(project_name)
if pos < 0:
        arcpy.AddError("This script must be run within the '" + project_name + "' ArcGIS Pro project.")
        sys.exit()
The project_name variable is used for many things within the scripts and ArcGIS Pro is changing them all to use g_ESRI_variable_1 because the project_name variable is instantiated with a string that is the same project name that the ppks file explodes to:
g_ESRI_variable_1 = os.path.join(arcpy.env.scriptWorkspace,'..\\commondata\\my_project_name1')
Once I realized that was the problem, and recognized it was the same problem I'd beaten my head against the wall over (repeatedly) many years ago, I intro'd the same fix I did then. I "hid" the string in question by complicating the code so ESRI stopped trying to "fix" it for me. So, now I have:
# project_name = "my_project_name"   # doesn't work
project_name = "_".join(["my","project","name"])
Et voila.
Similarly, though not for this particular problem, but in previous ones, we got around some of the problems by providing our paths with "/" rather the "\" and using Python's os.path.normpath functionality to convert the code to Windows structure at run time. ArcGIS wouldn't change those or the ones when we built the paths using the os.path.join (or path.pathlib.join_path, now) but there had to be enough parameters passed that ArcGIS couldn't figure out the path. I'm guessing, then, that the reporter of this problem could probably try something like this (no testing, just off the top of my head) to break things up and confuse ArcGIS Pro enough that it wouldn't try to change the script:
# checkout_image_path= os.path.join(homefolder,"current_checkout_attachments")‍‍
checkout_image_path= os.path.normpath(homefolder) + r"\\current_checkout_attachments")‍‍
Anyway, just throwing this stuff out there in case someone else comes across this thread looking for ideas.
Good luck!!
jtm
