Save field names to a .txt file
3038
11-26-2019 05:22 AM
SoratoSouza_e_Silva
how can i change this code to write to a file all field names of each feature class that exists in a geodatabase.
import arcpy
enviro = r"C:/EsriTraining/PYTH/Automate/"
arcpy.env.workspace = enviro +"{}".format("SanDiego.gdb")
field_list = arcpy.ListFields("MajorAttractions")
txtFile = open(enviro +"{}".format("Majorattractions.txt"),"w")
txtFile.write("MajorAttractions field information" + "\n")
txtFile.write("-------------------------------------" + "\n")
for field in field_list:
      line = "Name: {}, Type: {}, Length: {}\n".format(
            field.name, field.type, field.length)
      txtFile.write(line)
txtFile.close()
Thank´s
deleted-user-NvcfpBOWaKwr
Instead of trying to fix your code I just wrote this up. I tested it several times to make sure it works. The script will make a folder called "Logfiles" in the same directory path that the script is running from. There you will find the text file with the field information for all of the feature classes within the .gdb
Happy Thanksgiving, Enjoy and most of all enjoy the time ahead with the family!!
EDIT:
Added in some code to write the field type and length to the logfile. I missed that part when I grazed over your code.
You can also replace my concatenation's with the format() function. Especially on line 38. Bad habit on my end.
import arcpy
import os
from os import path
# Change the workSpace variable to point to the .gdb you want to work with
workSpace = r"Put the path of your .gdb here.. Make sure you keep the path within the double quotes and don't delete the r" # Sorry if you already know this.
logFile =  os.path.dirname(os.path.abspath(__file__)) + "\\" + "Logfiles" + "\\" + "Field_Export_Log.txt"
logFolder = os.path.dirname(os.path.abspath(__file__)) + "\\" + "Logfiles"
arcpy.env.workspace = workSpace
if path.exists(logFolder): # Checks to see if there is a Logfiles folder in the same directory path that the script is running from
    pass
else: # If there is not a Logfiles folder it will make one
    os.mkdir(logFolder)
if path.exists(logFile): # This checks to see if there is already a logfile. If there is one it will pass over this section
    pass
else:
    txtWriter = open(logFile, "a")  # If there is not a logfile it will create one
    txtWriter.write("******Begin Field Name Listing******")
    txtWriter.close()
for listFC in arcpy.ListFeatureClasses(): # This creates a list of the featureclasses within the .gdb and loops through each one
    describe = arcpy.Describe(listFC) # This pull information about the featureclass so we can use the .name method in the txt file
    txtWriter2 = open(logFile, "a")  # Opens the lofile
    txtWriter2.write("\n\n\n********" + " Field Names for Feature Class " + describe.name + " ********") # Writes some stuff to the log file
    for listFields in arcpy.ListFields(listFC): # This creates a list of the fields in the feature class that the loop on line 23 is currently on
        txtWriter2.write("\n\nName: " + listFields.name + "\nField Type: " + listFields.type + "\nField Length: " + str(listFields.length)) # This writes the field names, types and lengths to the logfile
        print("Added Field " + listFields.name + " From Feature Class: " + describe.name + " To .txt file") # For debugging so you know what the script is doing
    txtWriter2.close # This closes the write session on the logfile
print("Done!!!") # All done
EDIT:
import arcpy
import os
from os import path
    pass
    os.mkdir(logFolder)
    pass
else:
    txtWriter.close()
So to help you learn how I wrote the above code here are some good links to reading material.
Creating and working with directories in python:
https://stackabuse.com/creating-and-deleting-directories-with-python/
Reading and writing to text files with python:
Reading and Writing to text files in Python - GeeksforGeeks
ArcPy List Featureclasses:
ListFeatureClasses—ArcPy Functions | ArcGIS Desktop
ArcPy List Fields:
ListFields—ArcPy Functions | ArcGIS Desktop
ArcPy Field Object:
Field—ArcPy classes | ArcGIS Desktop
ArcPy Describe Function:
Describe—ArcPy Functions | ArcGIS Desktop
Hope this helps
SoratoSouza_e_Silva
Thank you very much
