Save all the layers in table of contents to layer files
1487
08-15-2012 09:26 PM
RaziMosadeghi
Hi, I have this big mxd containing 400+ layers under different groups. I was wondering if there is any python scripting to save all the layers to the layer files.
Regards
Razi
ChristopherThompson
This should work for you.. replace the stuff in red with the appropriate file paths. The script will find all the dataframes in your mxd and then save the layer files to the folder you specify.
  • Group layers are saved as such and named with the word 'Group' at the front so they are easily identified as such, but the individual layers inside a group are also saved - that may not be behavior you want so you may need to tweak that.
  • The naming of the saved layers is drawn directly from how the layers are named in your table of contents; again, if that isn't what you want you'll need to sort out how to name them more appropriately.
import arcpy, arcpy.mapping
ws = r'YOUR FILE PATH HERE TO WHERE LAYERS GET SAVED'
mxd = r'FILE PATH TO YOUR MAP DOCUMENT HERE'
mapdoc = arcpy.mapping.MapDocument(mxd)
dframes = arcpy.mapping.ListDataFrames(mapdoc)
for dframe in dframes:
    lyrs = arcpy.mapping.ListLayers(mapdoc,'',dframe)
    for lyr in lyrs:
        if lyr.isGroupLayer:
            l_name = 'group_' + lyr.name
        else:
            l_name = lyr.name
        arcpy.SaveToLayerFile_management(lyr,ws + '\\' + l_name + '.lyr')
RaziMosadeghi
Thank you for the quick reply
I tried the script but nothing happens! I have also tried the following script, which didn't work!
import arcpy
ws = arcpy.env.workspace(r"M:\SIS\ArcGIS Workspace\GIS_Project_lyrs\Dekho\lyrs\Test")
mxd = arcpy.mapping.MapDocument("CURRENT")
dframes = arcpy.mapping.ListDataFrames(mxd)
   lyrs = arcpy.mapping.ListLayers(mxd,'',dframe)
for lyr in lyrs:
   else:
       l_name = lyr.name
The mxd only has one datafram and I certainly need grouped layers as well as individual layers.
Would appreciate your help.
ChristopherThompson
thats odd, because i tested that script against several mxds before i posted it and it worked like a charm.  How are you executing the script?  I noticed this line inside the code you just posted:
the "CURRENT" keyword only works if you are running the script from within ArcMap I believe.  To run the code I gave you, open it with IDLE, replace the stuff in red, save it, then from the Run menu, select 'Run Module' and see if that helps.
Also, this line won't work I don't think:
you can't set an object/variable like ws with that statement it has to be on a line of its own.. you can do:
or
ws = r"M:\SIS\ArcGIS Workspace\GIS_Project_lyrs\Dekho\lyrs\Test"
arcpy.env.workspace(ws)
So you might try fixing those things and see if that works better for you.
RaziMosadeghi
Thank you that worked. I also got the following form ESRI Australia which worked perfectley
import arcpy
import os
mxdpath = arcpy.GetParameterAsText(0)
outdir = arcpy.GetParameterAsText(1)
mxd = arcpy.mapping.MapDocument(mxdpath)
arcpy.env.workspace = outdir
i = 0
for lyr in arcpy.mapping.ListLayers(mxd):
    outname = lyr.name
    if os.path.exists(outdir):
        outname = outdir + "\\" + outname
    i = 0
    out_i = outname + ".lyr"
    print out_i
    while os.path.exists(out_i) and i < 10:
        out_i = outname + "_" + str(i) + ".lyr"
        i += 1
    outname = out_i
    lyr.saveACopy(outname)
