Running python using server
7317
12
01-10-2024 06:20 AM
mody_buchbinder
I have a machine that has Pro 3.1.4 & server 11.1
When I run in CMD the python from server ("C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\python.exe") and try to import arcpy I get an error (see attachment) When I do it with the Pro python ("C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe") it works.
Both python version are the same (3.9.16)
I have tested it on a few machines that have both Pro & server installed. Some of them works, others do not.
Opened a case but the support does not have it on his machine.
Anybody have any idea?
When using the server python we should use the server license - this is the reason to use it.
Thanks
AllenDailey1
I had a similar problem a while ago.  Are you trying to use geoprocessing tools, and do you use Concurrent Use licenses for Pro?  Do you have a License Manager?  Through working with Esri, with a LOT of calls and back-and-forth, I learned that arcpy geoprocessing tools require that you're connected to the license manager in Pro.  It sounded like it's not possible to use arcpy geoprocessing tools via ArcGIS Server python... which just doesn't make any sense to me...
I don't know if any of that is relevant to your situation, but I thought I'd mention it just in case.
mody_buchbinder
Hi Allen
Thanks for your answer.
When I use the Pro python and the Pro have any licenses it works.
Many users does not want to use Pro license for this and would like to use Server license.
In ArcMap  python you should do "import arcserver" (https://desktop.arcgis.com/en/arcmap/latest/analyze/arcpy-functions/setproduct.htm) This does not exists in Pro arcpy.
The solution is to use the server python.exe that should use the server license automatically.
It does work on many machines but sometime does not on machines that have both Pro and Server installed.
ShaunWalbridge
Can you try to run the propy.bat included with the Server installation and see if the issue reproduces there? The documentation at https://enterprise.arcgis.com/en/server/latest/develop/windows/scripting-service-publishing-with-arc... provides some additional information. You can also try running the Python 3 Command Prompt from the start group shortcut and start your Python session from that to confirm it works when activated through conda.
Cheers, Shaun
mody_buchbinder
Hi Shaun
In most cases the reason to run server python is that we need to run python by scheduler a few times a day so the interactive mod does not help.
I tested the propy.bat at least on one machine and it did not worked. I will test it on other machines too.
Thanks
alex_friant
Did you ever figure this out?
I'm running into the same issue with propy.bat in ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\Scripts
One machine, two different accounts. Account#1 Server propy.bat works just fine when I try to import arcpy. Account #2 Server propy.bat opens but import arcpy has RunTimeError: The software is not authorized for use.
Being signed into ArcGIS Pro has zero effect on the outcome, on either account. Server should just be licensed to use arcpy, right?
DarylHochhalter
I have the same issue with the same versions Python 3.9.16 Server 11.1 and Pro 3.1, works on the Pro desktop machine not when I run it via remote desktop on the server machine. The very same script from the same location.
ERROR 000732: Input Table: does not exist or is not supported
The server is Standard the pro is advanced but this script uses arcpy.conversion.ExportTable which is available in either license.
One more thing, it was running on the server at 11.0, just upgraded to 11.1 and now doesn't run.
ModyBuchbinder
As far as i understand the order of installations (Pro and server) define if this will be a problem or not.
If you remove Pro from the server it works for me every time.
Sometime uninstall the Pro and then reinstall (if you must have it) works too
alex_friant
Thanks for the tip - that seems strange if true. The Pro installation should have nothing to do with the ArcGIS Server installation. If it does, then that means Pro is interfering with the normal operations of ArcGIS Server, which is concerning.
I'll give it a shot to see what I can figure out/duplicate the suggested work around.
ShaunWalbridge
I would appreciate a bug being logged on this, or sufficient detail for us to reproduce it in house. While the products and their registry keys should not interact, Python environments are a fairly special case. Why? Because once you create custom environments, they can be located anywhere on disk, and potentially map back to either Pro or Server or one of the other four products that also produce custom environments. In that case, mixing between environment types installed with different products can be problematic, because the versions won't align between those cases, and I suspect there is some interaction in that area at play here.
