Run ArcGIS python module in python CGI script for Apache server on OSX Lion Server
1181
03-14-2013 11:56 AM
PaulStine
I have ArcGIS 10.1 for Desktop running in a virtual machine on a mac computer with OSX Lion Server installed. I have also created a cgi python script for server side processing. I am wondering if it is possible to run the arcpy modules within the cgi python script running on the apache server.
In essence is it possible to simply copy the arcpy modules to a directory accessible by the apache server and then call them from the python cgi script?
MathewCoyle
Honored Contributor
If I understand you correctly... no, most of the the arcpy modules are only the python interface into the geoprocessor .dlls. Not only that you will need to be able to access your license as well. Your executing script will require access to the full ArcGIS installation. I'm pretty sure even attempting to circumvent this is in violation of your Esri EULA.
MathewCoyle
Honored Contributor
miaoyananmiao
hello mzcoyle. I am confused with how arcpy make it possible for python to import GIS functions. You said that"most of the the arcpy modules are only the python interface into the geoprocessor .dlls". so, would you like to tell me the details of arcpy. I just want to make sure how it works between python and ArcGIS. THANK YOU.
