rename layers displayed on TOC
19385
13
01-10-2012 05:27 AM
FugroSurvey_Ltd_
I???m brand new to Python so I???m not sure if what I want to do is possible or not and I apologise for my lack of technical terms.
Basically I need to export a few files from ArcMap to CAD on a daily basis. As part of company procedures my CAD layers need to have a specific name which is different from the original GIS layer name. The problem is that the Export to CAD tool picks up the name displayed on the TOC to create levels' name in CAD.
Having said that what I'm looking for is to make a script to rename all the layers on my TOC. Is this possible?
I appreciate any help or pointers in the right direction.
PT
Raphael_Augusto_FoscariniFerre
Is there a way to change the 'label' of the layerfile? The script above, changes the layer name. But i want to change the layer name. I'm refering to the name is written right after the symbol, in the TOC.
RebeccaStrauch__GISP
since you posted this question https://community.esri.com/message/673130-re-how-can-i-change-the-layer-label-in-toc-with-py you may want to delete your comment/question above.  If geonet doesn't allow you to, I might be able to do it for you.
i'm just trying to get as many options as possible.
I figured how to do it. I just need to change it, the way i want one time, than save a .lyr from the correct information (it can also change symbology, and other stuff).
The script below, will apply the .lyr file to your layer in the TOC. You just must specify the name of the layer, like displayed in TOC.
It will do to all MXD files, in the same folder of the script.
import arcpy, os
from arcpy import env
env.workspace = os.curdir
for mxdFile in arcpy.ListFiles("*.mxd"):
    mxdPath = env.workspace + "\\" + mxdFile
    mxd = arcpy.mapping.MapDocument(mxdPath)
    layers = arcpy.mapping.ListLayers(mxd)
    for lyr in layers:
        if lyr.name == "layer_name_in_TOC": #change here
            print mxdPath
            symbologyLayer = r"D:\LayerFile.lyr" #change here
            arcpy.ApplySymbologyFromLayer_management (lyr, symbologyLayer)
            arcpy.RefreshTOC()
            mxd.save()
