Removing parts of a string field python calculator
14671
7
08-29-2014 12:30 PM
StephenNorris
whats the syntax for removing a specific number of characters from a string.
for example "name.pdf" I want to remove from the right the ".pdf"
Sorry this is a basic question. my searches aren't finding the answer.
Steve
JakeSkinner
Esri Esteemed Contributor
Hi Stephen,
You can use the split method.  Ex:
txt = "name.pdf"
txt.split(".")[0]
This will return 'name'.
StephenNorris
I'll try that one too. I actually used a successful search strip and found another answer.
!Field_name! .rstrip(".pdf")
StephenNorris
Also I was using the field calculator in arcmap. in case that changes anything
StephenNorris
Thanks for the replies everyone. much appreciated
DanPatterson_Retired
or a little more cryptic
>>> txt = "name.pdf"
>>> a = txt[:-4]  #strip off last 4 characters
>>> a
'name'
the [  ] means that text is whats called an iterable, meaning each character can be cycled through
the [:   means copy everything from the beginning (note the colon after the [ )
the -4] means everything except the last 4 characters (counting from the right)
hence it all means copy the "txt" variable (name.pdf) except the last 4 characters
MatthiasAbele
Hi Stephen,
it would be easier to to it with Excel using the GISconnector.
In Excel, use search/replace or strip the characters with =right(), =left()...
Best
Matthias
Well whatever Excel can do python can do as well
>>> txt = "name.pdf"
>>> stripped = txt.rstrip(".pdf")
>>> stripped
'name'
