remove the last word in a string
13796
08-16-2012 10:22 AM
DanielErklauer
How does one remove the last word in a string if the field I am querying has variable character lengths?  I.e:
1234 S Man 77025
123 Main 00865
I want to remove the zip code here but the character counts vary.
MathewCoyle
Honored Contributor
This should do what you want. Where var is your string.
var.split(" ")[:-1]
If the portion of the string you are trying to remove is always the same length, you could also use the simpler.
var[:-6]
MathewCoyle
Honored Contributor
var.split(" ")[:-1]
var[:-6]
BruceNielsen
" ".join(var.split()[:-1])
Will return the original string, minus the last word.
ColeSutton11
Thank you Bruce. Exactly what I needed.
