SearchCursor row methods missing?
2409
5
09-14-2022 06:59 AM
mmann1123
Using arcpy 3.0 - all the row methods described here appear to be missing for a feature layer in a file geodatabase??
For instance the only printed methods for the following
with arcpy.da.SearchCursor(in_table="Crashes_in_DC",
field_names="Tot_PedBik",) as cursor:
    for row in cursor:
         print(dir(row))
 are
'count', 'index'
So
    for row in cursor:
        print(row.getValue('Tot_PedBik'))
returns:
AttributeError: 'tuple' object has no attribute 'getValue'
Tags (3)
BlakeTerhune
That documentation is referring to the legacy cursor, but your code sample is using the new "data access" cursor. I'm surprised the legacy cursor documentation isn't more clearly identified here. The new "da" cursors returns the row data as a Python tuple (instead of a row object), which only has the methods built in for a tuple. To access data in a particular field, use the index of the field.
                          field_names=["Tot_PedBik"]) as cursor:
    for row in cursor:
        print(row[0])
Here, it's using index 0 because that's the index of Tot_PedBik in the field_names parameter (which should be a list, even with one field).
mmann1123
How do you open a bug report for this kind of stuff?
BlakeTerhune
There's a feedback option at the bottom of all documentation pages. I already submitted my feedback on this, but you're welcome to submit your feedback too.
BlakeTerhune
    for row in cursor:
        print(row[0])
mmann1123
Ha... Yeah that's totally unclear from the docs but makes sense.
Luke_Pinner
MVP Regular Contributor
If you want to use field names to refer to row values instead of tuple indexes, you can convert the row to a dict:
with arcpy.da.SearchCursor(feature_class, ["list", "of", "field", "names"]) as rows:
    fields = rows.fields
    for row in rows:
        row = dict(zip(fields, row))
        print(row['SOMEFIELD'], row["ANOTHERFIELD"])
