Remove Alph and special characters from string filed
5540
10
08-31-2016 11:51 AM
2Quiker
I have a table with a field called group_code and in this field there strings like the following.
2,10,12,15H, 26P, 35$#. As you can see some have a alph and special characters and some don't. So i don't think i can use the cursor.updateRow([row[0][1:-1]]).
I need to remove all the Alph and special characters at the end of each column for the group_code field.
I have tried the following but no luck. I need this to be outside the field calculator.
table = r"C:\Temp\Default.gdb\LandVal"fieldValue = "group_code"
#Removes alpha at the end  for field in arcpy.ListFields(table, "group_code", "String"):
       exp = ''.join([i for i in fieldValue if i.isdigit()])
arcpy.management.CalculateField(table, field, exp.format(field), "PYTHON")
arcpy.conversion.TableToTable(table, r"C:\Temp", "LandVal_Test.dbf")‍‍‍
ClintonDow1
Cursors can replace the CalculateField call to make it a bit clearer.
with arcpy.da.UpdateCursor(file, ['group_code']) as cursor:
   for row in cursor:
      s = row[0]
      row[0] = "".join([c for c in s if c.isnumeric()])
      cursor.updateRow(row)
edit: forgot the updateRow call
