Reading and writing
3138
12
03-06-2021 12:18 AM
Mick
LanceCole
MVP Regular Contributor
Mick,
Are you trying to crawl through a folder looking for files and their path?  I use the following to reclusively look for a particular file type in a folder and subfolders.  The function call below returns a list containing the folder and filename for all "txt" files in a directory and its subdirectors.
import os, fnmatch
def locate(pattern, root=os.curdir):
  for folder, subs, files in os.walk(root):
    for filename in fnmatch.filter(files, pattern):
      yield os.path.join(folder, filename)
filelist = locate('*.txt', r'D:\path')
DavidPike
MVP Notable Contributor
Python File Write (w3schools.com) - be very careful which mode you open the textfiles in, as this can delete them inadvertently.  e.g. 'w', 'a', 'ab'... I'd really recommend on reading up on them first.
#the os.path.join method is useful for joining paths
import os
#folder that texfiles will be saved in
myfolder = r'D:\Downloads'
#name of your textfiles
textfile_name_1 = 'demo1.txt'
textfile_name_2 = 'demo2.txt'
#concatenate(add together) path strings
textfile_path_1 = myfolder + '\\' + textfile_name_1
textfile_path_2 = myfolder + '\\' + textfile_name_2
#see the resulting paths
print(textfile_path_1)
print(textfile_path_2)
#or I prefer to use os.path.join
textfile_path_1 = os.path.join(myfolder, textfile_name_1)
textfile_path_2 = os.path.join(myfolder, textfile_name_2)
#open/create a textfile and write to it
#the 'w' means write, but will also delete and
#recreate the entire textfile if already exists
f = open(textfile_path_1, 'w')
f.write('I have created a textfile and written this line to it')
f.close()
#the with statement means no .close() method is needed
with open(textfile_path_2, 'w') as text_file:
    text_file.write('I have created a tetxfile and written this line to it')
Mick
Unfortunately, I have more than one hundred files in the folder, so it is very difficult to indicate all of them.
DavidPike
What do you want to actually do?
LanceCole
Mick,
import os, fnmatch
DavidPike
wow you were ready for that one!
import os
my_folder = r'D:\Downloads'
file_list = []
#walk your folder
for root, dirs, files in os.walk(my_folder):
    for filename in files:
        #join filename to folder path
        filepath = os.path.join(my_folder, filename)
        #print to test the functionality
        print(filepath)
        #you can also append all the filepaths to a list, rather
        #than within this generator.
        #also added a test for .txt in filename
        if '.txt' in filename:
            file_list.append(filepath)
    break
Mick
Yes, you are right. I have tried and received "line 9, in <module>
with open(filelist,"r") as f:
TypeError: coercing to Unicode: need string or buffer, generator found".
LanceCole
Mick, if you are referencing the filelist from Dave or my examples you iterate through the list using:
for fp in filelist:
  # fp is the full path and filename for each item in the filelist
  with open(fp,"r") as f:
    # do what you need here with the file data
Mick
I have a syntax error for "as" in        open(fp, "r") as f.
DavidPike
for fp in filelist:
  with open(fp, "r") as f:
