Reading and writing
4523
12
03-06-2021 12:18 AM
Mick
LanceCole
Sorry, I left the "with" out of the statement when I cut and pasted.  I have corrected my previous post.
LanceCole
No fair David, you can type faster than I can.
One other note.  Make sure you use a Python raw string for your path.  This will treat the backslash (\) as a literal character and not as an escape character.  David has included this in is example by using the lower case (r) in front of his path "myfolder" string.
myfolder = r'D:\Downloads'
LanceCole
Per your question on how to run this on multiple file extensions, the simplest solution is just to call the locate function multiple times.  Such as:
for ext in ('*.txt', '*.thn', '*.csv'):
  # This will run three times first returning all
  # the TXT files, then THN,and finally CSV files
  filelist = locate(ext, r'D:\path')
  for fp in filelist:
    # Do what you need to with this file
    # You can also use the variable 'ext' here to
    # process files differently base upon the 'ext'
