Re: delete duplicates records based on field
1417
04-11-2023 01:37 AM
Sebastian-VlăduțCristea
Hello!
I have this repetitive "RO." and I want to delete but keep "AB, AR, AG, BC ... etc". How can I do that?
Tags (1)
AlfredBaldenweck
MVP Frequent Contributor
Try a field calculator.
In Arcade:
Replace($feature.HASC_1, "RO.", "")
Test on one record before doing the whole table.
BlakeTerhune
Yep. Calculate Field is what you want. For variety, here's the Python equivalent.
!HASC_1!.replace("RO.", "")
by Anonymous User
Not applicable
@Sebastian-VlăduțCristeaI moved this to be its own question because that thread was posted back in 2016.
To remove the RO. you can use an update cursor:
with arcpy.da.UpdateCursor(fc, ['HASC_1']) as uCur:
    for row in uCur:
        row[0] = row[0].split('.')[-1]
        uCur.updateRow(row)
updatecursor-class.htm
