Query for Service Definition
644
11-21-2024 08:02 AM
kapalczynski
I am attempting to query for a service definition and getting list index out of range errors... not sure why.
Is it because it cant read it... the Service Definition is shared publicly so should not be permissions...
Any thoughts
sd_fs_name = "NeighborhoodUtilityPermits"
portal = "https://www.arcgis.com"
user = "username" # username that has permissions to the Feature Layer
sdItem = gis.content.search(query="title:"+ sd_fs_name + " AND owner: " + user, item_type="Service Definition")[0]
Search for original SD on portal…
File "C:\Users\Desktop\Portal_to_AGOL_Processing\ProcessingtoAGOL\AGOL_Module.py", line 96, in <module>
IndexError: list index out of range
CodyPatterson
MVP Regular Contributor
Hey @kapalczynski
If you remove the [0] is the GIS search returning an empty list, or a list at all? You may try print(type(sdItem)) to see if it's returning a certain type that isn't a list.
If it isn't returning anything in the list or is an empty list, check your content.search to be sure it's querying correctly.
Cody
