Python won't recognize NULL (or None)
19346
13
09-26-2011 01:11 PM
RichardThurau
Trying to calculate a field based on another field. Want to give Contiguous a "Y" where Contig_ID is not NULL.
"Calculate Field for Contiguous"
Field Name: Contiguous
Expression: Answer(!Contig_ID!)
Code Block:
def Answer(CI):
  if CI ==None:
    return "N"
  else:
    return "Y"
I've read plenty of posts explaining that NULL == None in python, but this code only returns Y for all numeric values in Contig_ID. Where Contig_ID == Null, no values are returned to Contiguous.
Any help would be grand!
Rich
BarryHall
Joshua -- many thanks -- I am a Python newbie -- does the Python None object equate to false in logical tests?
JoshuaBixby
MVP Esteemed Contributor
Yes, see 2.3.1 Truth Value Testing .  Since there are several other data structures that exhibit falsy behavior, e.g., an empty string, testing for false instead of for None might result in some non-NULL fields getting treated as NULL.
BarryHall
Why is an individual field attribute an object (re:Null is returning as a Python  None object)?
JoshuaBixby
Anything returned from any field in a cursor is a Python object because all data types are fundamentally objects:
>>> lst = [int(), float(), str(), bool(), None]
>>> for obj in lst:
...   print(isinstance(obj, object))
True
True
True
True
True
In terms of why NULL gets returned as None; well, None is the closest data type conceptually to SQL NULL:  Built-in Constants — Python 3.7.4 documentation
None
The sole value of the type NoneType. None is frequently used to represent the absence of a value, as when default arguments are not passed to a function.
