pt_geom = arcpy.PointGeometry(arcpy.Point(x, y))
class LineToPolyTool(object): """Implementation for LineToPoly_addin.linetopoly (Tool)""" def __init__(self): self.enabled = True self.cursor = 3 self.shape = "Line" def onLine(self, line_geometry): array = arcpy.Array() part = line_geometry.getPart(0) for pt in part: print pt.X, pt.Y array.add(pt) array.add(line_geometry.firstPoint) polygon = arcpy.Polygon(array)
Hi Szymon,There is no specific shape for point or polygon. To construct the point, you must use onMouseDown or onMouseDownMap. Using the x and y coordindates you can construct the point geometry.pt_geom = arcpy.PointGeometry(arcpy.Point(x, y))For polygon, we hope to include this for final. For now, you would need to use line and close it off. Here is an example:class LineToPolyTool(object): """Implementation for LineToPoly_addin.linetopoly (Tool)""" def __init__(self): self.enabled = True self.cursor = 3 self.shape = "Line" def onLine(self, line_geometry): array = arcpy.Array() part = line_geometry.getPart(0) for pt in part: print pt.X, pt.Y array.add(pt) array.add(line_geometry.firstPoint) polygon = arcpy.Polygon(array)I hope this is helpful. Jason PardyEsri
It's just a Polyline object.
