Python Scripting Problem
2219
11-12-2013 09:39 PM
H_A_D_Padmasiri
I wrote a python script. when it run the following message display
SyntaxError: unexpected character after line continuation character (Script1.py, line 29)
Failed to execute (LISTool1.0).
I cant understand what,s wrong with my script
Can you help me
T__WayneWhitley
Honored Contributor
The line that includes your query is escaping quotes wrong-- this doesn't work:
" " \Layer\ " LIKE 'BOUND%'  AND " \Layer\ " NOT LIKE 'BOUND-ADMIN-VIR' "
The quote escape works like this:  \"  ...or this:  \'
So try this:
" \"Layer\" LIKE 'BOUND%'  AND \"Layer\" NOT LIKE 'BOUND-ADMIN-VIR%' "
Test it - and if your single quotes are also giving trouble (I don't think they will), then try this:
" \"Layer\" LIKE \'BOUND%\'  AND \"Layer\" NOT LIKE \'BOUND-ADMIN-VIR%\' "
..enjoy,
Wayne
MathewCoyle
Honored Contributor
You can eliminate the confusing escape characters by using string substitution and the AddFieldDelimiters function.
query =  "{0} LIKE 'BOUND%'  AND {0} NOT LIKE 'BOUND-ADMIN-VIR'".format(arcpy.AddFieldDelimiters(Polyline, 'Layer'))
arcpy.FeatureClassToFeatureClass_conversion(Polyline, Fea_Class_Path, "PCL_LN", query)
Also, I don't see your Polyline variable declared anywhere.
