Python Parameters change in ArcPro 3.2.1
1072
01-10-2024 11:12 AM
-j-b-
Hello,
Does anyone know if the Python parameters changed or if there is a logged bug with arcpy.conversion.ExportFeatures when used in Pro 3.2.1?
After upgrading Pro, it seems that the field mapping properties are no longer coming through when using python but works when the tool is run manually.
Thank you!
Julianna
DanPatterson
MVP Esteemed Contributor
BUG-000164320 for ArcGIS Pro (esri.com)
plus more but nothing that specifically mentions field mapping
... sort of retired...
