Python notebook to delete features in hosted table when any set of 3 values in 3 distinct fields repeats
2520
11-09-2023 12:00 PM
DavidFrisbey
Hi super smart Esri Community,
I am seeking a solution to delete rows in a hosted table through python script in a notebook on AGOL. I can't use any solution that touches a local file like a csv file.
The chunk before this need is:
# delete features with where avg_ is less than 2
Carc.delete_features(where="avg_ < 2")
The need is something that will delete all rows from this table if three distinct fields within Carc repeat.
For example, in the picture below, the solution would leave each row in the table with a unique set of 3 values in the fields sensor_id,  time_stamp, and avg_. So, in the picture below, the solution would leave the 2 first rows and remove 2 of 4 of the last 4 rows, because they have non-unique sets of sensor_id,  time_stamp, and avg_.
Best,
Eli L
KellyTaylor
I haven't tested this so you may have to mess with it a bit but I believe the logic is solid
AlfredBaldenweck
MVP Frequent Contributor
DavidFrisbey
Thank you, Alfred. I don't normally use the advanced runtime required for arcpy, yet it is a simple, good solution and I appreciate your time and help.
KellyTaylor
DavidFrisbey
Thank you, Kelly. That works great!
