Python method to change spatial reference of query layer?
962
05-17-2023 10:17 AM
DanCall1
I am using ArcGIS Pro 3.04. I have a bunch of maps in several APRX files which contain query layers, each based on a different SQL database view. Those maps are published to an ArcGIS Portal site. The data behind the database views is changing: the spatial reference is currently a state plane system but is being converted to web mercator. The query used for these layers is just one line, selecting everything that's in the database view.
I already have a process to update all the SQL views, but I need to update the query layers to the new spatial reference. In the GUI, I can do this in the layer properties, Source tab: When I re-validate the query (the query doesn't need to change), Pro re-examines the view and selects the correct SRID.
Is there any way to automate the process of changing a query layer's SRID? I've done some searching and it doesn't look like it's possible. I know I can change the connection properties using arcpy, but as far as I've seen it's not possible to update the details of a query layer (either changing the query text, or changing the SRID).
RogerDunnGIS
I'm curious on one point.  How do you know that it's being converted?  Online maps and ArcGIS Pro will try to project-on-the-fly, and they usually try to match a map's basemap layer's coordinate system.  That's where I'm curious.
