Python Map Algebra error: Failed to execute (output)
3059
07-08-2015 10:49 PM
KarolinaKorzeniowska
Dear Jake,
I have a problem with another equation where I am using minimum and maximum value from my data. I am using the following code:
RI_tif = "C:\\output.tif"
# Process: Get Raster Properties
arcpy.GetRasterProperties_management(v6_tif, "MINIMUM", "")
# Process: Get Raster Properties (2)
arcpy.GetRasterProperties_management(v6_tif, "MAXIMUM", "")
# Process: Raster Calculator (3)
outSubt = (Raster("6.tif")-(float(Property))/((float(Property (2))-(float(Property))
outSubt.save("C:\\output_tif")
I have an error in the last line "Failed to execute (output)." I think that the problem is with the min, max values which I am using in the equation. Probably I implemented them in a wrong way. However, I could not find at ESRI website some example how to do this. Do you have maybe idea how to implement these values in python?
Thanks in advance.
Tags (1)
curtvprice
Here's a formatted version of your code:
I don't think you're translating very well from the ModelBuilder export.  That can be a challenge, but that's how we learn sometimes.
The following would work better.  Note how I'm not working on the root folder of your C drive but one folder beneath it (usually a good idea for many reasons).
import arcpy
from arcpy.sa import *
from arcpy import env
env.workspace = "C:\\workspace"
input_tif = "v6.tif" # in c:\workspace
gridmin = float(arcpy.GetRasterProperties_management(input_tif, "MINIMIMUM"))
gridmax = float(arcpy.GetRasterProperties_management(input_tif, "MAXIMUM"))
outRaster = Raster(input_tif) - (gridmin / (gridmax - gridmin))
outRaster.save("output.tif")
