How to obtain number of cells in neighborhood from NbrWeight neighborhood object?
4020
10-15-2015 10:06 AM
AmelieDavis
I'd like to get the first two numbers in the .txt file that is loaded as by NbrWeight (neighborhood object weights) for the focal statistics tool.
I want to use them to calculate the area of the rectangle that is the neighborhood.
How do I easily access the values?
Here is what I have so far:
inWeightFile = arcpy.GetParameterAsText(5)
if inWeightFile == '#' or not inWeightFile:
    inWeightFile = "C:\\temp\\PPR\\Test\\bee_kernel_2_5km.txt" # provide a default value if unspecified
# Create the Neighborhood Object for the buffer
myNbrWeight = arcpy.sa.NbrWeight(inWeightFile)
# Get number of cells in the buffer
NbrCellsBuffer = 65 * 65 # XXX need to fix this. Should come from first two numbers in inWeightFile
# Process: Focal Statistics - within buffer calculate sum of f_rc1_H1 with exponential decay function and divide by number of cells in buffer
arcpy.AddMessage("Calculate proportional cover of high floral quality classes within buffer for first floral season")
f_rc_f_H1 = (arcpy.sa.FocalStatistics(f_rc1_H1, myNbrWeight, "SUM", "NODATA") * outConstRaster) / NbrCellsBuffer
Any help is greatly appreciated.
Best,
Amelie
Luke_Pinner
MVP Regular Contributor
ncols, nrows = [int(s) for s in open(inWeightFile).readlines()[0].strip().split()]
NbrCellsBuffer = ncols * nrows
The above opens the file and grabs the first line, strips off the newline ('\n') character and splits it into a list of two strings at the space then uses python list comprehension to convert the strings to integer values.
DanPatterson_Retired
showing the text file would be useful
AmelieDavis
yes, sorry.
The text file is just the kernel they talked about here  ArcGIS Desktop saved as a .txt.
I'm attaching my kernel (it's a bit more complicated than the examples provided in the help).
Amelie
Luke_Pinner
curtvprice
Amelie,
Irregular neighborhoods could be implemented better in arcpy. Here's more fun I've had with them:
Working with kernel files in arcpy: NbrIrregular bug
That is one massive kernel file!
