Python efficiency with Rasters
1160
5
09-21-2012 12:54 PM
RobinCheskin
The script below multiplies two rasters, where the cell value of one raster is a parameter.
#Import modules
import os
import arcpy
from arcpy import env
from arcpy.sa import *
arcpy.CheckOutExtension("Spatial")
#Set local variables
wks = arcpy.GetParameterAsText(0) # input workspace
inRaster1 = arcpy.GetParameterAsText(1) # input raster layer
env.workspace = wks
#Perform Constant Raster Function
constantValue = arcpy.GetParameterAsText(2) # input weight value
cellSize = 100
outExtent = Extent(871599.89, 982834.44, 912502.09, 1070920.9)
outConstRaster = CreateConstantRaster(constantValue, "FLOAT", cellSize, outExtent)
outConstRaster.save("temp1")
#Perform Times Function
outTimes = Raster(inRaster1)* Raster("temp1")
outRaster1 = "Wt_" + os.path.basename(inRaster1)
outTimes.save(outRaster1)
#Create script output and delete constant raster
arcpy.SetParameterAsText(3,outRaster1)
arcpy.Delete_management("temp1")
This works, but is not optimal and much slower than I would like.  I tried this code without saving outConstRaster and just calling it as a raster object, but I kept getting the same error: "TypeError: expected a raster or layer name."  This will also need to work for up to 10 different raster layers.
Any thoughts on making this more efficient?
ArkadiuszMatoszka
Occasional Contributor II
First of all, don't save constant value raster, if you using it only ones, just use it in multiplication. It will remove few operations (saving, rereading and deleting). Another thing, is type of raster, use "Float" only if necessary, operations or floating numbers are much more complex for processor.
import os
import arcpy
env.workspace = wks
cellSize = 100
if int(constantValue) == constantValue:
  type = 'INTEGER'
else:
  type = 'FLOAT'
outConstRaster = CreateConstantRaster(constantValue, type, cellSize, outExtent)
outTimes = Raster(inRaster1)* outConstRaster
RobinCheskin
Thank you, this worked nicely for the single raster.  The challenge I am facing is creating the script for up to 10 rasters:
#Import modules
import os
import arcpy
inRaster2 = arcpy.GetParameterAsText(2) # input raster layer
inRaster3 = arcpy.GetParameterAsText(3) # input raster layer (optional)
inRaster4 = arcpy.GetParameterAsText(4) # input raster layer (optional)
inRaster5 = arcpy.GetParameterAsText(5) # input raster layer (optional)
inRaster6 = arcpy.GetParameterAsText(6) # input raster layer (optional)
inRaster7 = arcpy.GetParameterAsText(7) # input raster layer (optional)
inRaster8 = arcpy.GetParameterAsText(8) # input raster layer (optional)
inRaster9 = arcpy.GetParameterAsText(9) # input raster layer (optional)
inRaster10 = arcpy.GetParameterAsText(10) # input raster layer (optional)
env.workspace = wks
#Multiply Raster by a constant with CreateConstantRaster
constantValue1 = arcpy.GetParameterAsText(11) # input weight value
constantValue2 = arcpy.GetParameterAsText(12) # input weight value
constantValue3 = arcpy.GetParameterAsText(13) # input weight value (optional)
constantValue4 = arcpy.GetParameterAsText(14) # input weight value (optional)
constantValue5 = arcpy.GetParameterAsText(15) # input weight value (optional)
constantValue6 = arcpy.GetParameterAsText(16) # input weight value (optional)
constantValue7 = arcpy.GetParameterAsText(17) # input weight value (optional)
constantValue8 = arcpy.GetParameterAsText(18) # input weight value (optional)
constantValue9 = arcpy.GetParameterAsText(19) # input weight value (optional)
constantValue10 = arcpy.GetParameterAsText(20) # input weight value (optional)
cellSize = 100
outConstRaster1 = CreateConstantRaster(constantValue1, "FLOAT", cellSize, outExtent)
outConstRaster2 = CreateConstantRaster(constantValue2, "FLOAT", cellSize, outExtent)
outConstRaster3 = CreateConstantRaster(constantValue3, "FLOAT", cellSize, outExtent)
outConstRaster4 = CreateConstantRaster(constantValue4, "FLOAT", cellSize, outExtent)
outConstRaster5 = CreateConstantRaster(constantValue5, "FLOAT", cellSize, outExtent)
outConstRaster6 = CreateConstantRaster(constantValue6, "FLOAT", cellSize, outExtent)
outConstRaster7 = CreateConstantRaster(constantValue7, "FLOAT", cellSize, outExtent)
outConstRaster8 = CreateConstantRaster(constantValue8, "FLOAT", cellSize, outExtent)
outConstRaster9 = CreateConstantRaster(constantValue9, "FLOAT", cellSize, outExtent)
outConstRaster10 = CreateConstantRaster(constantValue10, "FLOAT", cellSize, outExtent)
#Create weighted raster layer with Times
outTimes1 = Raster(inRaster1)* outConstRaster1
outTimes2 = Raster(inRaster2)* outConstRaster2
outTimes3 = Raster(inRaster3)* outConstRaster3
outTimes4 = Raster(inRaster4)* outConstRaster4
outTimes5 = Raster(inRaster5)* outConstRaster5
outTimes6 = Raster(inRaster6)* outConstRaster6
outTimes7 = Raster(inRaster7)* outConstRaster7
outTimes8 = Raster(inRaster8)* outConstRaster8
outTimes9 = Raster(inRaster9)* outConstRaster9
outTimes10 = Raster(inRaster10)* outConstRaster10
outRaster2 = "Wt_" + os.path.basename(inRaster2)
outRaster3 = "Wt_" + os.path.basename(inRaster3)
outRaster4 = "Wt_" + os.path.basename(inRaster4)
outRaster5 = "Wt_" + os.path.basename(inRaster5)
outRaster6 = "Wt_" + os.path.basename(inRaster6)
outRaster7 = "Wt_" + os.path.basename(inRaster7)
outRaster8 = "Wt_" + os.path.basename(inRaster8)
outRaster9 = "Wt_" + os.path.basename(inRaster9)
outRaster10 = "Wt_" + os.path.basename(inRaster10)
outTimes.save(outRaster2)
outTimes.save(outRaster3)
outTimes.save(outRaster4)
outTimes.save(outRaster5)
outTimes.save(outRaster6)
outTimes.save(outRaster7)
outTimes.save(outRaster8)
outTimes.save(outRaster9)
outTimes.save(outRaster10)
env.workspace = wks1
arcpy.SetParameterAsText(21,wks1)
I have been toying around with ToolValidator b/c the script has to skip over creating a constant raster & performing times if there is no parameter (after the first 2 raster layers & weight values the parameters are optional).  Unfortunately I am stuck again.
Help would be greatly appreciated...!
RobinCheskin
This is what I came up with, which seems to be working:
#Import modules
import os
import arcpy
wks1 = wks
env.workspace = wks
cellSize = 100
outTimes1.save(outRaster1) # save raster
outTimes2.save(outRaster2)
#isinstnace test for parameter input
if isinstance(constantValue3, ()):
      outTimes3.save(outRaster3)
else:
      sys.exit()
if isinstance(constantValue4, ()):
      outTimes4.save(outRaster4)
else:
      sys.exit()
if isinstance(constantValue5, ()):
      outTimes5.save(outRaster5)
else:
      sys.exit()
if isinstance(constantValue6, ()):
      outTimes6.save(outRaster6)
else:
      sys.exit()
if isinstance(constantValue7, ()):
      outTimes7.save(outRaster7)
else:
      sys.exit()
if isinstance(constantValue8, ()):
      outTimes8.save(outRaster8)
else:
      sys.exit()
if isinstance(constantValue9, ()):
      outTimes9save(outRaster9)
else:
      sys.exit()
if isinstance(constantValue10, ()):
      outTimes10.save(outRaster10)
else:
      sys.exit()
curtvprice
I'm not so clear how you are using the isinstance() function. The usual way to do this with arcpy is by examining the returned value of arcpy.GetParameterAsText(). If the argument was not provided (and was not populated using script tool defaults or in validation code) the GetParameterAsText() result will be an empty string (not None, since the function always returns a text string).
if arcpy.GetParameterAsText(2) != "":
    do stuff with arcpy.GetParameterAsText(2)
ArkadiuszMatoszka
Right, you can also use simple:
if arcpy.GetParameterAsText(2):
Empty string is treated as Boolean False, so if there is no parameters nothing will be done.
