CreateArcSDEConnectionFile_management and transaction version dbo.DEFAULT selection
3744
09-25-2012 03:13 AM
JohnLay
I am trying to make a database connection with the CreateArcSDEConnectionFile_management function in python. Everything works fine EXCEPT that I have to manually change the connection details to dbo.DEFAULT before the connection is usable (I have to do the same even if I am creating the connection through Catalog--Click the Change button in the Connection details section, Choose the dbo.DEFAULT, Click OK on the Connection Details dialog box to close it.)
Is this a known issue?
Is there a work around that can be scripted so that the user does not need to exit the script and manually perform this step?
JakeSkinner
Esri Esteemed Contributor
Hi John,
Are you specifying the 'version' parameter?  Ex:
arcpy.CreateArcSDEConnectionFile_management("C:/Projects","SQLEXPRESS", "SDE_SERVER","sde:sqlserver:SDE_SERVER/sqlexpress","Data","OPERATING_SYSTEM_AUTH","#","#","SAVE_USERNAME","dbo.DEFAULT","SAVE_VERSION")
JohnLay
Yep, I am specifying dbo.DEFAULT as the version parameter. Once the database connection is created, I have to manually edit the connection properties and specify dbo.DEFAULT as the version again before it will connect.
[HTML]database = r"Database Connections\CENSUS.sde"
if arcpy.Exists(database):
    pass
else:
    arcpy.CreateArcSDEConnectionFile_management ("Database Connections", "CENSUS.sde", "CENSUS", "sde:sqlserver:00.00.000.000", "CENSUS", "DATABASE_AUTH", "USER", "PASS", "SAVE_USERNAME", "sde.DEFAULT", "SAVE_VERSION")[/HTML]
JakeSkinner
Hi John,
According to the code you posted, you are specifying 'sde.default' (2nd to last parameter).  Try changing this to dbo.default.
JohnLay
Nope, wait. Looks like I DIDN'T specify dbo.DEFAULT as the version but sde.DEFAULT instead. I should have uploaded the script to begin with.
Thanks Jake for pointing that out.
